- Thank you received: 2098
At my wits end! Still running lean
16 Jun 2010 16:53 #376157
by Patton
Replied by Patton on topic At my wits end! Still running lean
fordtruck wrote:
Per FSM, '77KZ1000 fuel level is 2~4 mm under edge of carb body.
And FSM trouble shooting guide lists incorrect fuel level as possible cause for several performance issues.
I checked the fuel levels this morning using the clear tube method. My manual says the level should be 4mm below the carb body. Three of the carbs were ok, but one was 6mm below the body. I corrected it. Is 2mm too low enough to cause problem? I didn't have time for a test ride.
- fordtruck
- Thank you received: 6
16 Jun 2010 17:11 #376161
by fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
Replied by fordtruck on topic At my wits end! Still running lean
Thanks Patton. I should mention that the carbs are 1980 VM28's. Is it better to be too low or high?
- larrycavan
- Visitor
16 Jun 2010 17:44 #376169
by larrycavan
Replied by larrycavan on topic At my wits end! Still running lean
Put some miles on it and check your plugs.
16 Jun 2010 17:58 #376170
by Patton
Uncertain whether might help or hinder, but wondering if Dynojet kit (with jet needles) might reduce the mid-range surging.
Click > Dynojet Kit from Z1E
