?carb
- b.tracy79kz
11 Jun 2010 12:55 #375118
by b.tracy79kz
?carb was created by b.tracy79kz
ok dont know where to start.1979 kz1000 ltd with 26mm carbs,120 main jet,header 4 into 1,air pod filters,15 pilot,wont hold a idle without choke on ,cut coke off bike wont stay idling just dies out.need help,and thank you so much if you can.p.s. dont help to turn idle up,just gets worce.is 120 to much fuel?
- Thank you received: 2098
11 Jun 2010 14:07 #375128
by Patton
Replied by Patton on topic ?carb
b.tracy79kz wrote:
Would suspect imperfect carb pilot circuits for whatever reason, such as clogged fuel and/or air passages, damaged pilot jet, etc.
WEAR PROTECTIVE GOGGLES when spraying carb cleaner.
[Click on image to improve view.]
11 Jun 2010 18:13 #375159
by Patton
Stock main is 105R and pilot 15.
Imo, 120 main isn't causing the reported idle problem, and not affecting idle or lower speed running at all for that matter.
The bike, when new, idled just fine with 15 pilot.
Imo pods don't affect pilot circuit mixture all that much.
In any event, won't hurt to try next size larger pilot jets, as these models were tuned lean because of EPA regs.
With pods, should expect additional carb tuning efforts, and probably never get performance throughout throttle range as good as stock airbox.
- gothic92kz1000
13 Jun 2010 20:31 #375596
by gothic92kz1000
Replied by gothic92kz1000 on topic ?carb
what is your timeing set on it might be off:)
