CARB: a cleaning story.
  • purerider
  • purerider's Avatar Topic Author
23 Oct 2005 23:08
#3749
Just started my first ever carb cleaning of my '76 750B1. Got some pictures to show you all. Maybe these will be helpful to some people.
  • luvmykaw
  • luvmykaw's Avatar
Re: CARB: a cleaning story.
24 Oct 2005 09:39
#3828
You can see something queered up already pr. The left spring is binding. After the outside is spotless, do one carb at a time so you don't mix up parts. You can check this place out for parts if you wish.
www.z1enterprises.com/
  • purerider
24 Oct 2005 16:44
#3926
yea, I've noticed that also.
Is there any good online info on Carb rebuilding/cleaning? I've researched and came up with nothing new.
  • GargantuChet
  • GargantuChet's Avatar
24 Oct 2005 21:18
#3997
I've read that everywhere, but I'm not clear on why. Are the parts different for each carb in the set, or is it just a matter of parts wearing together?
I think we should have a carb write-up, with pictures...
Post edited by: GargantuChet, at: 2005/10/25 00:18
  • savedrider
  • savedrider's Avatar
  • 1975 Z1-B 900
24 Oct 2005 21:30
#4003
I think the point behind that is so you don't make things more complicated than they need to be. If you really decide to tear down a whole set of carbs completely you will find yourself with a mess of parts. Perhaps having one to look at as a reference will also help.
Get right or get left! <*{{{><
  • luvmykaw
  • luvmykaw's Avatar
24 Oct 2005 21:58
#4015
I have a ton of crap for you to read, some with pictures. Email me and I'll send you a pile of stuff.
aquamarine52@yahoo.com
This is one of my email addys. Explain who you are in the title so I don't dump you as an unknown, ok ?
  • wiredgeorge
  • wiredgeorge's Avatar
25 Oct 2005 06:13
#4049
It doesn't really matter if you swap MOST parts from carb to carb except for a few... Take the slides for instance. Over time, wear occurs between the slide and carb body. They travel in the carb body much easier if you put them back where they go. It would be tough to make a list of the FEW things that really need to go back where they came from so it is just easier to state that you should put all parts back where they came from. Generally speaking the parts that work best returned to their original location are those that move and wear against another part, like the slides.
  • GargantuChet
25 Oct 2005 06:49
#4064
That makes sense. Thanks for the reply!
