Will not throttle down between gear changes!
- BIGD
07 Jun 2010 15:01 #374166
by BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
Will not throttle down between gear changes! was created by BIGD
Could an opinion givin as to why my engine will not throttle down between gear shifts, and seems to not idle down quickly when coming to a stop in 1st gear.
- MFolks
- Thank you received: 540
07 Jun 2010 15:12 #374170
by MFolks
Replied by MFolks on topic Will not throttle down between gear changes!
I'd say two things could cause this:
1.Vacuum leak.
2.Stuck mechanical ignition advancer.
To find the vacuum leak, warn up the engine, then spray brake cleaner around the rubber carb boots(ducting)and the carb holders between the engine and carbs.The rubber plugs on the vacuum sync. fittings also need replacing too as they crack with heat/age
If the idle goes up, you've found the leak.
The ignition advancer is located behind a CD sized cover on the right side of the engine(as you sit on the seat).
Remove the cover with the engine off and give it a twist by hand, if it does not return to it's original position, cafefully note how it's installed, remove it and clean/lubricate it.
Light sewing machine oil or 3-in-one oil is what I have sued on my bike advancer for years.
1.Vacuum leak.
- BIGD
07 Jun 2010 15:17 - 07 Jun 2010 15:18 #374174
by BIGD
Replied by BIGD on topic Will not throttle down between gear changes!
I will try both and let you know. Thanks Don
Last edit: 07 Jun 2010 15:18 by BIGD.
- PLUMMEN
- Thank you received: 104
07 Jun 2010 15:55 #374186
by PLUMMEN
Replied by PLUMMEN on topic Will not throttle down between gear changes!
id guess a vacuam issue
