VM26SS Mikuni Installation..
- Soulmighty
Thanks!
- Thank you received: 2098
Would anyone have a good source for installation instructions for a set of VM26SS Mikuni carbs? They are from a '77 kz1000 ltd and I am putting them on a Z1 Classic in place of EFI. I know all the specifics related to the manifolds, pods etc. however I cant seem to figure out how the fuel lines and air lines hook up. Can anyone help? This is my first project and I want to get it right....
Note that with a single fuel line from petcock into carbs, there is only one "T" fuel pipe, in the middle between the inside carbs.
See also the following post regarding vent tube routing
[Click on image for better view.]
An alternate routing for vent tubes, preferred by some, is to exit to open air underneath the bike (along with the overflow hoses).
- Soulmighty
- mjg15
Your cluch cable routing doesn't look like it should. Unless you intentionally did it that way, it should follow lower frame tube when leaving the case and then follow the downtube upward toward the steering stem. They way it is now it looks like it tear-up that nice finish on your header.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
- Soulmighty
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
The clutch cable is meant for the original handlebars which were longer than the ones I have now. Any suggestions on where to find a shorter clutch cable? Thanks!
Z1E will have shorter clutch cable. Might be from standard model such as KZ1000-A1/2/3, or KZ1000-D1/2 cafe racer, or other models.
Would inquire at Z1E via telephone or email inquiry.
Click > www.z1enterprises.com/
- Soulmighty
...wiring diagram....
May download many different wiring diagrams and other information for particular years and models by going into Filebase under KZ Information (in the green ribbon toward top of screen).
See below for navigation aid.
[Click on image to enlarge view.]
