failed emissions test
- jklcycles
- Avondale, AZ
HC limit is 1800. She was 1858. CO limit is 5.50. She was 5.91. I am running the stock 28mm carbs. I have a set of 26mm from a KZ1000. Anyone know if the 26mm would run leaner? Any suggestions?
1975 Z1-B. Current project.
1977 KZ1000. Future project.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Just put in 1 size smaller pilot jet and tune it real lean on the screws before the test.
Ride it for at least an hour before hand, then keep tuning the screws leaner and leaner and raise the idle, till it starts to hesitate when pulling away, then backup your screw changes by a half turn.
Then your good to go!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Old Man Rock
- Thank you received: 225
1) Ride to the testing station.
2) Before going in line, lean out the pilots where barely idling on it's own. ~ 1 - 1.5 turns.
3) Tweak back "Rich ~ 1/16th to 1/8th turn so it does idle during the test... As you know, once the test starts you're not allowed to touch/tweak in the bay...
4) Turn the engine off and then try and restart... If she is too hard to start or you have to choke her way out to start, tweak them a tad (1/16th of a turn) richer.
5) Take her in the bay...
Following this procedure, at the time I did this last year, my jets where off as follows and still easily passed...
Main Jets: Have dropped 2 sizes
Slow Jets: (pilots) dropped 2 sizes
Needle: Dropped 1 size leaner
I just had to go through myself, was slightly over mid way in the measurements.... June, this may no longer be required... :woohoo:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- larrycavan
- Visitor
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
Brings up another thought....
When was the last time a thorough tune up was performed?
Valve clearances, carb sync, ignition timing etc...
Assumption is it runs well, no smoke, sparkies look good not black/carbon/oiled/soot etc...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
"420Hp XJR Jag. "... Glows bright florescence green... :blink:
Your just jealous because your A4 only gets 32MPG. (and that is if you push it for the last two miles) :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
:blink:
It's only in that configuration when my wife is driving. But also than the millage is a bit lower.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- larrycavan
- Visitor
When it comes to bikes....I'll take BHP over MPG
How about some pics of that Jag
