hissing at idle
- b.tracy79kz
05 Jun 2010 07:55 - 05 Jun 2010 07:56 #373616
by b.tracy79kz
hissing at idle was created by b.tracy79kz
26mm carbs,i have a hiss or pop sounds like air hiss?is this carb or timing?only at idle,vacuum ports on carbs(2) should they be plugged or put hoses on them.they where plugged when i got the bike,but mechanic said he thinks they should be open?is this the hiss? i do have 15 pilot jet,if that's too small.
Last edit: 05 Jun 2010 07:56 by b.tracy79kz.
- Nebr_Rex
- Thank you received: 300
05 Jun 2010 08:00 #373618
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic hissing at idle
2 of them are for fuel bowl vents and one is for "vacuum" to the fuel tap
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- b.tracy79kz
05 Jun 2010 11:52 #373686
by b.tracy79kz
Replied by b.tracy79kz on topic hissing at idle
i dont have the one for the fuel tap.
- Thank you received: 2098
05 Jun 2010 12:18 - 05 Jun 2010 12:19 #373691
by Patton
Replied by Patton on topic hissing at idle
During normal operation, the two float bowl air vent hoses should exit to open air.
And other nipples should be capped/plugged (usually vacuum nipples on carb holders which are used when syncing carbs).
[Click on image to enlarge view.]
Last edit: 05 Jun 2010 12:19 by Patton.
05 Jun 2010 12:21 - 05 Jun 2010 12:22 #373692
by Patton
Last edit: 05 Jun 2010 12:22 by Patton.
