intake boots, can I make them larger?
  • 77KZ650
  • 77KZ650's Avatar Topic Author
06 Apr 2006 15:25
#37301
Hey everyone, Im swapping up to 28mm carbs on my 810 project, My question is, can I make my intake boots larger to accept the larger carbs? something like "boring" out the intake boots? can this be done to rubber easily? or should I just get the larger boots?(for $70)
Any imput would be appreciated. thanks
Scott
07 MDP Rookie of the Year
  • wireman
  • wireman's Avatar
Re: intake boots, can I make them larger?
06 Apr 2006 15:41
#37305
i know you can shove 29s into stock k1000 boots for 26mm carbs.;) goodluck,happy wrenching!
  • 77KZ650
06 Apr 2006 15:48
#37306
Whats the OD of the 26 carbs?
  • steell
  • steell's Avatar
06 Apr 2006 15:59
#37313
I have a set of J model carb holders that I got from Z1, and I'm pretty sure I paid ~$40 for a set of four.
You have to elongate the bolt holes to make them fit though.
I checked and they are now $48.80, still a lot cheaper than $70 though.
www.z1enterprises.com/detail.aspx?ID=314
Post edited by: steell, at: 2006/04/06 19:02
  • wiredgeorge
  • wiredgeorge's Avatar
06 Apr 2006 18:15
#37386
The VM29 and VM28 OD is actually smaller than the OD on a VM26. All fit the same intake manifolds. You can't enlarge an intake manifold. You need to buy new ones. The mount holes are slightly different width and will need to be elongated.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
06 Apr 2006 18:39
#37399
Actually a Rat biker could enlarge a intake rubber. I found a piece of pipe the appox. size i needed and heated it up with the torch and Wa-LA,Inlarged boots. Please be in a well ventelated area. Roy:woohoo:
  • 77KZ650
06 Apr 2006 20:43
#37429
www.z1enterprises.com/detail.aspx?ID=314 <br><br>Post edited by: steell, at: 2006/04/06 19:02
I guess I was figuring shipping and the swap to CAD$ for the $70 figure
So does anyone know the OD for a 28? I need to see if its "close enough" to the OD of the 24s to see if I can modify my intake boots. thanks
Scott
  • wireman
  • wireman's Avatar
06 Apr 2006 21:38
#37442
im gonna shoot in the dark here and say just under 30mm feel free to shoot this theory full of holes guys! :whistle: :woohoo: goodluck,happy wrenching!
  • 77KZ650
06 Apr 2006 21:45
#37445
If youre right, that would be awesome! my 24s are right around 30mm OD
  • 782david
  • 782david's Avatar
07 Apr 2006 05:10
#37508
I enlarged the boots on the air box side of the carbs by warming them with a torch and forcing them down over the neck of a beer bottle. This softened the boot and with a larger carb size made it alot easier to install them. Not sure if this will wirk for the engine side.
  • wiredgeorge
07 Apr 2006 05:40
#37516
Good luck... I can see you have more advice on this subject than you need already so I will butt out! bwhahahaha Just remember what I mentioned when you try fitting those 28s in the 24 intake manifolds hehe
  • 77KZ650
07 Apr 2006 09:05
#37566
Thanks a lot guys, Ill give it a go, and if I screw it up, theres always Z1 with lots of new ones.
