damage from leaky intake manifolds
- seige
02 Jun 2010 20:08 #372975
by seige
damage from leaky intake manifolds was created by seige
I was wondering how much damage could result from a leaky carb intake manifold? I plan on replacing them soon and am not riding her(78' kz650) till I do, but I noticed it after I bought it and drove it about 150 miles home. It seemed to stop once she warmed up, but still bogs and almost stalls when releasing the clutch. Would this be from the air leak or something else?
Thanks
Thanks
- TeK9iNe
- What did you do!?!
- Thank you received: 28
02 Jun 2010 21:07 #372994
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic damage from leaky intake manifolds
Could deffinately be from an air leak, especially if the idle hangs up for a couple seconds when your off the throttle.
It could also be the advancer sticking/timing being off/bad points.
Or mixture screws not tuned properly/leaking carb enrichener circuit.
Head gasket leak/low compression...
blah blah blah...
:blink:
If the bike didn't overheat/sieze, it likely didn't harm too much.
GL!
blah blah blah...
:blink:
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bountyhunter
- Thank you received: 337
02 Jun 2010 21:09 #372996
by bountyhunter
Replied by bountyhunter on topic damage from leaky intake manifolds
If the spark plugs tips look white, it could be lean enough to damage something run long enough.
