floats
- b.tracy79kz
02 Jun 2010 18:09 #372925
by b.tracy79kz
floats was created by b.tracy79kz
ok,if you guys seen all my post for info.the carbs are done.,all most,when i went to set float bowl level.it seemed ,that i had to bend tabs a lot.to get 26mm form carb body?is this normal,ive never seen a tab bent so much?thanks for any feed back.
- Thank you received: 2098
02 Jun 2010 18:13 - 02 Jun 2010 18:21 #372927
by Patton
Replied by Patton on topic floats
b.tracy79kz wrote:
Imo, should forget float height, and concentrate on actual fuel level as shown by the clear tube test, which FSM may refer to as the "service fuel level."
The same apparently identical float height measurement in all carbs may result in different actual fuel levels among the carbs, and maybe none of them within specs.
Last edit: 02 Jun 2010 18:21 by Patton.
02 Jun 2010 18:19 #372929
by Patton
On some carbs, it's possible to inadvertently install the floats upside down. :pinch:
02 Jun 2010 18:26 #372932
by Patton
02 Jun 2010 18:27 - 02 Jun 2010 18:31 #372933
by Patton
Last edit: 02 Jun 2010 18:31 by Patton.
02 Jun 2010 18:30 #372937
by Patton
