- Thank you received: 2098
VM 28 SS on 1980 KZ1000 A4
04 Jul 2010 06:13 - 05 Jul 2010 06:15 #380111
by Patton
Replied by Patton on topic VM 28 SS on 1980 KZ1000 A4
Backfiring through carb may result from too tight clearance on the intake valve.
Last edit: 05 Jul 2010 06:15 by Patton.
- hwrecker
04 Jul 2010 10:26 #380157
by hwrecker
Replied by hwrecker on topic VM 28 SS on 1980 KZ1000 A4
what about the idling issue that the other guy had when he decel to a stop? if you bog the enging down with the clutch it will stay down at normal. sometimes. could that valve clearance be causing the backfiring too?
05 Jul 2010 06:14 #380340
by Patton
hwrecker wrote:
While backfiring through carb may result from too tight clearance on the intake valve, popping through the exhaust when decelerating may result from too lean carb pilot circuit.
Racing idle may result from an air leak from such places as cracked or worn or torn carb holder, loose clamp (holding carb in the holder), leaking vacuum cap (plug).
- hwrecker
05 Jul 2010 10:25 #380378
by hwrecker
how can I correct the lean carb? would you think that cleaning the carbs is in order after it sat for a few years?
- hwrecker
05 Jul 2010 15:05 #380415
by hwrecker
and what is this timing advanvcer that the other guy was considering cleaning?
