carb cleaning
- b.tracy79kz
30 May 2010 18:32 #372181
by b.tracy79kz
carb cleaning was created by b.tracy79kz
is the best way to clean carbs,are to soak them?and if so with what or the best way you kaw guys know.thanks
- Thank you received: 2098
30 May 2010 20:21 #372212
by Patton
Replied by Patton on topic carb cleaning
b.tracy79kz wrote:
Which of these carbs look the most like yours?
--- Manual slide with side-located pilot air screw
--- Manual slide with bottom-located pilot mixture screw
--- CV "Constant Vacuum" slide with top-located pilot mixture screw
30 May 2010 20:26 #372213
by Patton
Wear protective goggles and use a lot of carb spray.
This is for manual slide with side-located pilot air screw.
[Click on image to enhance view.]
- Link14
- Thank you received: 6
30 May 2010 20:49 #372220
by Link14
Replied by Link14 on topic carb cleaning
Hey Patton,
I'm actually going to be doing the above procedure on my 900's VM26's. The manual doesn't give a setting for the air screw other than to line up the screw notch with the notch on the case (which none of mine are). I was going to screw them all in to figure out how far out each were set, but if you know a good start setting for the air needles I'd appreciate hearing it.
Thanks (sorry to highjack post)
30 May 2010 21:07 #372223
by Patton
Link14 wrote:
It's 1.25 turns out from lightly seated.
...setting for the air screw...good start setting for the air needles I'd appreciate hearing it....
