Missing Airfilter Frame - Any work arounds?
- SanyarcoKeith
30 May 2010 05:01
Hi all.
I got an '82 750 Spectre, as a gift, a few months back. I'm trying to get it on the road now. I got a new stock oiled foam filter. I go to put it in and realize a) the old filter is not even there but b) the air filter frame is missing. I looked on eBay and didn't see any. Is there some type of work around for this that doesn't involve switching to pod filter? Just wondering if maybe I could switch to a replacement K&N or some type of pleated filter (that will keep its shape) and then wouldn't need filter frame.
Any help is appreciated.
1982 750 Spectre
Re: Missing Airfilter Frame - Any work arounds?
30 May 2010 06:22 - 30 May 2010 06:23
SanyarcoKeith wrote:
Here's the parts diagram.
Which parts are missing?
[Click on image to enlarge view.]
Hi all.
Last edit: 30 May 2010 06:23 by Patton.
30 May 2010 06:31 - 30 May 2010 06:36
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's one of the several current ebay listings.
Search ebay for KZ750 airbox
Search ebay for KZ750 air box
Last edit: 30 May 2010 06:36 by Patton.
- JMKZHI
30 May 2010 07:17 - 30 May 2010 07:18
He probably needs the element holder for the filter element. You might try searching the part number at ebbaayy. Also, a UniFilter element may still be available. Alternatively, I'd guess that a pleated filter would be suitable. Check Z1Enterprises.com - I like to search there by model. The air filter would be in the maintenance section. Good luck.
Last edit: 30 May 2010 07:18 by JMKZHI.
- SanyarcoKeith
30 May 2010 10:11
The part I am missing is 13091A - its the filter frame. I have a foam element and need that frame.
What I'm wondering is can I just use a pleated filter and then not need the frame? I've looked and didn't find one on eBay.
Thanks for the responses!
1982 750 Spectre
30 May 2010 12:17 - 30 May 2010 12:20
Okay, the frame that fits inside the foam element and holds it in shape. Part No. 13091-1147
According to kawasaki.com, the part is no longer active.
It's listed at
speedsupplies.com/partslisting.asp?posit...ment=500&category=KW
13091-1147 HOLDER, ELEMENT $10.53
I see no reason a pleated filter wouldn't do just fine, provided it fits without any air leaking around it when fitted into place. Locating a suitable size pleated filter may be a challenge.
Wondering if the part is metal or plastic or ??? and whether feasible to construct a serviceable homemade part.
It's listed at
Last edit: 30 May 2010 12:20 by Patton.
30 May 2010 12:24
JMKZHI wrote:
Check Z1Enterprises.com - I like to search there by model. The air filter would be in the maintenance section. --- the best advice.
Click > www.z1enterprises.com/detail.aspx?ID=1495
30 May 2010 12:35
This may fit, as it's the paper filter on bikes the K&N is supposed to replace.
Click > www.z1enterprises.com/detail.aspx?ID=1973
Could ask the good folks at Z1E about it.
Or just roll the dice and order it. :woohoo:
- hocbj23
30 May 2010 12:37
some coathanger wire,a pair of good sidecutters,a little snip here and there .looks like an easy fab.bj
