headers are red when motor warms up
- nathanhopkins
29 May 2010 22:45 #372021
by nathanhopkins
headers are red when motor warms up was created by nathanhopkins
So am i running lean or rich what do i need to do to fix issue float bowl adj or needles highe or lower
- MFolks
- Thank you received: 540
29 May 2010 22:49 #372022
by MFolks
Replied by MFolks on topic headers are red when motor warms up
Color of the sparkplug center insulators? If white, you're far too lean, Black being rich, and a light tan, just about right.
How long do you warm up the engine? These air cooled engines will run really hot without air going through the cooling fins.
- nathanhopkins
29 May 2010 22:57 #372023
by nathanhopkins
Replied by nathanhopkins on topic headers are red when motor warms up
noticed riding down the road pipes were bright red .
- Thank you received: 2098
30 May 2010 06:14 #372035
by Patton
Replied by Patton on topic headers are red when motor warms up
Would also check ignition timing.
And assure correct spark plugs are installed.
- Bluemeanie
- Thank you received: 14
30 May 2010 06:21 #372036
by Bluemeanie
Replied by Bluemeanie on topic headers are red when motor warms up
MFolks wrote:
Like this idiot?
(youtube)
nathanhopkins, sounds like you have unburned fuel being ignited in the exhaust system. You need to check ignition and fuel system for too rich or ignition system for poor or no spark.
Like this idiot?
(youtube)
- Motor Head
- Thank you received: 391
30 May 2010 06:33 #372045
by Motor Head
Replied by Motor Head on topic headers are red when motor warms up
While checking the Ignition be sure that the advancer is working, as if not the timing will be retarded at RPM which will cause high exhaust temps. I've seen Super Trap muffler inserts melt from this on big block chev's.
- nathanhopkins
30 May 2010 07:56 #372063
by nathanhopkins
30 May 2010 09:04 #372070
by Patton
Thinking 1978 KZ750 twin.
