air leak
- seige
29 May 2010 15:16 #371917
by seige
air leak was created by seige
I recently bought a 1978 kz650sr. Great bike. Only 10k, bone stock. I recently noticed when she is warming up one of the carbs has an air leak up front. I can see a mist of fuel spraying from between the carb mount and engine. Any thoughts?
- Motor Head
- Thank you received: 391
29 May 2010 15:23 #371919
by Motor Head
Replied by Motor Head on topic air leak
Probably broke a carb intake manifold, they are rubber seamed to metal and they seperate. Time for some new manifolds, clean out you carbs/ kit them, and check the connectors to the air cleaner housing as those may need replacing as well.
- seige
29 May 2010 15:37 #371923
by seige
Replied by seige on topic air leak
Thanks for the info, doesn't sound that difficult to do. The guy I bought it from said he recently cleaned the carbs and I also noticed no. 2 and 3 has missing spring clamps. cheers.
- Motor Head
29 May 2010 16:42 #371944
by Motor Head
Have you got a proper repair manual for your bike? If stuff is missing/ etc from the last guy I would be pulling the carbs apart while I had em off as they can take awhile to get back in, much harder with old air boot to the air box.
- Old Man Rock
- Thank you received: 225
29 May 2010 17:05 #371953
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic air leak
Bottom right...
KZ650 Service manual for free download....
jarlef.no/Kawasaki/Series/Z/650/z650files.htm
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
