Pod Filters - the effect of running them...
- Jeff.Saunders
If you pull the stock airbox and replace it with pod filters, MAKE SURE YOU SUPPORT THE CARBS.
The weight of the carbs and pod filters will shred the carb holder very quickly.
A bank of carbs full of fuel with a set of K&N pods weighs well over 10lb - that is all unsupported weight bouncing up and down as you ride.
Fabricate one or two straps - something as simple as a couple of strong zip ties looped over the frame.
www.z1enterprises.com
Z1 Ent on Facebook,
- TeK9iNe
- What did you do!?!
- Thank you received: 28
I too have seen the results of an unsupported rack... :laugh:
We all know what that leads to. :ohmy:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- RonKZ650
- Thank you received: 240
- larrycavan
- Visitor
I'm happy the Z1 expert agrees with me on this one. I've said this for years, but there's guys on here that claim they have run 30 yrs without the manifolds going to crap with unsupported carbs to which I call balony. If not balony, then exceptionally lucky anyway.
Count me in with the "balony / lucky" gang because I've never had a bit of trouble running pods on KZ motors with OEM. In fact, this is the first time I've heard anyone even mention it.
I see lots of KZ heads and the intake boots are never destroyed from that. Aged and cracked..for sure but not shreded up from running unsupported carbs with pod filters....
Must be more balony / lucky guys out there than the other kind... :woohoo:
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- will61310
- Thank you received: 6
Non support = Droopy rack?....:SThis is very good info Jeff.
...1980 LTD 1000...
- timebomb33
