Confirm no needle settings on an '80 KZ650E?
- WillaminaOR
26 May 2010 12:35 #371091
by WillaminaOR
Confirm no needle settings on an '80 KZ650E? was created by WillaminaOR
I was going to post looking for how to pull the needles out of the carbs on my 80 kz650e so as to change the clip setting. I searched a little and it looks as if there isn't any other setting available? Can someone confirm this for me?
So I'd need to get bigger jets? It's got pods on it now.
Thanks,
Bryan
Thanks,
Bryan
- Old Man Rock
- Thank you received: 225
26 May 2010 12:42 #371097
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Confirm no needle settings on an '80 KZ650E?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
The following user(s) said Thank You: predalm
- WillaminaOR
26 May 2010 15:14 #371145
by WillaminaOR
Replied by WillaminaOR on topic Confirm no needle settings on an '80 KZ650E?
I'm sure that'll be helpful even though it's an 81 manual. Assuming the manual is the same for an 80 than it says that there are no setting for the US model.
Where does that leave me? Bigger main jets? The bike has had pods put on it and I'll be putting some, more than likely, freer flowing mufflers on it cause they are mismatched now. I'm not sure the idle jets but the mains were 97.5. I've got the air screws at either 1 turn out or 3/4 turn out and that seem to have the low end and part throttle pretty good. Pops when I'm decelerating. Feels like it could use some more fuel when I'm at wider throttle openings and if I whack it all the way open it pretty much just refuses to accelerate at all. I thought I read that the air screw affects all the circuits though so should I be looking at fattening up both the mains and idle so the air screw can be closer to two turns out as suggested?
Thanks,
Bryan
Thanks,
Bryan
- andrewsowen
01 Jun 2010 21:50 #372752
by andrewsowen
1980 KZ650F
Replied by andrewsowen on topic Confirm no needle settings on an '80 KZ650E?
If you have the VM's on it the carbs should have adjustable jet needles. The carbs off my '80 KZ650F had VM's that you could change the clip postion.
1980 KZ650F
- Motor Head
- Thank you received: 391
02 Jun 2010 06:03 #372788
by Motor Head
Replied by Motor Head on topic Confirm no needle settings on an '80 KZ650E?
Even if the needles have only 1 clip slot, you can shim the needles, as they sell needle shims. Also there is a chart from Mikuni where you can buy a richer needle, cheaper than a needle jet. Order some mains as well, trail and err with lots of spark plug readings.
