Missing overflow drain tubes?
  • kz750saskatoon
  • kz750saskatoon's Avatar
Re: Missing overflow drain tubes?
26 May 2010 18:03
#371186
3mm is about 0.14" and 1/8" is 0.125". It'll maybe be a bit tighter but it should work.
1981 KZ750-H2
Saskatoon, SK
26 May 2010 18:23
#371197
When dealing with an almost too snug tube fit, may dip end of hose or tube into a cup of boiling water for a few seconds, and then it usually slips easily onto the nipple.
I just heat a half cup of water in the microwave.
Sometimes a little silicone lube will suffice, but imo the hot water dip works better.
This applies to any of the various carb tubes, hoses, and fuel line also.
Good Fortune! :)
  • JR
  • JR's Avatar
26 May 2010 19:07 - 26 May 2010 19:09
#371213
For that black overflow tubing I use windshield washer tubing which I find in the autoparts store or Mallwart in the area where you find the wiper blades. The tubing comes in a little box with about 2M of 6 feet and not only is it oil and gas resistant and stays flexible but it is cheap. I cant remember the ID. Perhaps 7/32 ...whatever that is. I'm to used to metric :)
Last edit: 26 May 2010 19:09 by JR.
  • 550A2
  • 550A2's Avatar
  • keep the shiny side up
26 May 2010 22:30 - 26 May 2010 22:33
#371275
everyone is right..use any tubing that will fit snugly. metric or SAE doesnt matter much as long it will fit and not fall off. fuel resistance is a plus!
seafoam it!!!!!!! all seafoam does is break down crud in your fuel system and it burns hot, it burns off the carbon on your valves, combustion chamber ect.
I love seafoam, i soak jets and carb parts in pure seafoam.works gooood!:cheer:
-luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Last edit: 26 May 2010 22:33 by 550A2.
  • gte105u
  • gte105u's Avatar Topic Author
27 May 2010 05:25
#371294
But can you overdo it in your fuel tank? I would hate to dump half a can in at fill-up and melt something. Never used it before.
1981 KZ550 A2
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
27 May 2010 06:04 - 21 Feb 2013 01:49
#371300
Last edit: 21 Feb 2013 01:49 by H1Vindicator.
