Missing overflow drain tubes?
- gte105u
1981 KZ550 A2
- xLowEndx
- Slappa da bass
On my 750 those hoses go right into my air box and if I'm correct they are 1/4" tubes.
1980 Kawasaki KZ750-H1 LTD
- JMKZHI
- Thank you received: 48
- TeK9iNe
- What did you do!?!
- Thank you received: 28
The leak is being caused by an improperly seating float valve needle.
If the leak isnt too bad, get yourself a can of SeaFoam.
Dump the whole thing into a fresh tank of gas and run the old girl till its gone.
This can, and often does fix that problem, as well as clean things nicely inside your carbs.
The drain tubes SHOULD NOT be routed to your airbox. They are supposed to drain down completely away from all intake and combustion sources.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- xLowEndx
- Slappa da bass
GL!
Really? I have actual OEM grommets that go inside of my airbox that come out of the bottom of my carbs on my 1980 KZ750.
This isn't correct or am I just confusing the overflow tubes???
- gte105u
What does "3.5x550" mean? I am assuming that would be in millimeters? I looked up the part from Bike Bandit and would rather not pay the $20/pop it costs. Is this something I can get from the auto parts store, or do I need to pick up from a local cycle service? I will route down and out, and trim so it hangs down. Anything special I should know? I guess you can just have them hold in place with zip ties? I know I am full of annoying questions, but thanks all for the help.
I have seen several tips on the Sea Foam. The leak is not bad, overnight there is a very small spot on the floor. I will give it a shot, if not may try flushing to see if it helps.
1981 KZ550 A2
- Thank you received: 2098
Here's routing on KZ900-B1 LTD. Loosely bundled together and routed behind engine to exit underneath bike.
- H1Vindicator
- Thank you received: 53
- JMKZHI
Yep, that is mm. And yes, you can get the tubing from the auto parts store etc. - it's nothing special. Mine isn't zip-tied or anything - it seems to stay in place - it's a snug fit between the engine & swingarm.What does "3.5x550" mean? I am assuming that would be in millimeters? I looked up the part from Bike Bandit and would rather not pay the $20/pop it costs. Is this something I can get from the auto parts store, or do I need to pick up from a local cycle service? I will route down and out, and trim so it hangs down. Anything special I should know? I guess you can just have them hold in place with zip ties? ...
- gte105u
www.amazon.com/gp/product/B002S9Y0A2/ref...ie=UTF8&s=automotive
1981 KZ550 A2
- DoubleDub
- Visitor
- gte105u
I picked up a can of SeaFoam. Sales guy said it works great. Directions say to use one ounce per gallon of fuel. Will it help/hurt to use more? I was thinking of using half a can for two tank fills which is about double the directions. Thanks for the help guys.
1981 KZ550 A2
