STARTER PLUNGER LEAKING?
- juliorice
26 May 2010 10:42 #371051
by juliorice
STARTER PLUNGER LEAKING? was created by juliorice
IS THERE A WAY TO TEST IF THE STARTER PLUNGER IS LEAKING CAUSING A RICH CONDITION AT LOW RPM? THANKS. JULIO
- TeK9iNe
- What did you do!?!
- Thank you received: 28
26 May 2010 12:52 - 26 May 2010 12:57 #371102
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic STARTER PLUNGER LEAKING?
YES THERE IS!
IF YOU CANT PROPERLY TUNE THE MIXTURE SCREWS AT IDLE, OR FIDLING WITH THE CHOKE CAUSES A NOTICABLE (AUDIBLE) CHANGE IN RPM.
THERE MIGHT BE SOME OTHER WAYS... SOMEONE WILL PIPE UP!
PEACE!
:woohoo: :laugh: :laugh:
Sorry for yelling...
Check your plugs. If a rich condition is suddenly occuring on one plug and not the others its probly somethin else, like some debris blocking the pilot temporarily.
Usually if there's a leak in the choke/enrichener system, you can feel it at all throttle inputs.
Make sure you have clean strong spark!
Lots of compression!
and clean fresh gas.
Tune your mixture screws right!
GL.
PEACE!
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 26 May 2010 12:57 by TeK9iNe.
