1978 kz650 D1 keeps bogging down.
- sneekydevil
26 May 2010 07:12 #370998
by sneekydevil
1978 kz650 D1 keeps bogging down. was created by sneekydevil
Hey all. Just joined the group and am loving the bikes. I have a 78 kz650 D1 that bogged down yesterday as I was going upward in elevation. Got the bike back down closer to sea level, and it is still bogging down. I looked at the fuel bubbler and it has an air bubble in it. Is that normal to have air in the bubbler? And can anyone help me with the bogging down problem. thanks for any help guys. Ride safe.
- Kawickrice
- Thank you received: 18
26 May 2010 07:34 #371006
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic 1978 kz650 D1 keeps bogging down.
Sounds like some trash in the carbs. Did you hit reserve recently? Has it always done this or just started recently?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- sneekydevil
26 May 2010 08:07 #371018
by sneekydevil
Replied by sneekydevil on topic 1978 kz650 D1 keeps bogging down.
I have not hit the reserve recently, cause I keep it filled up. And it just started this yesterday.
- Kawickrice
26 May 2010 09:19 #371038
by Kawickrice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Could be a number of things. I would check your fuel cap to make sure the vent is not clogged. Try running the bike with the cap open and see if it helps if so you have a clog in the vent if not we will go to step 2.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- RetroRiceRocketRider
- Thank you received: 29
26 May 2010 10:15 #371048
by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic 1978 kz650 D1 keeps bogging down.
Welcome to KZr sneekydevil.
By "fuel bubbler", I'm assuming you mean fuel filter?
If so, and depending on it's size, it wouldn't be uncommon for it to have a small air bubble in it. If it is to large (or very fine mesh) filter, it can possibly cause your stated problem, since your bike might be consuming fuel faster than it can actually filter it. It even might be as simple as it being clogged.
FWIW, most problems can often be traced back to what maintenance or changes have recently been performed (oil / filter change, cleaned air filter, etc.) on a bike.
- sneekydevil
28 May 2010 13:52 #371676
by sneekydevil
Thanks to everyone who had advice. Got the bike fixed. Seems that some paint chipped off in the gas tank. Just a spec, but enough to keep the bike bogging down. Drained the carbs and she runs like a champ. Thanks again.
