bike wont idle
- sgtusmc05
23 May 2010 19:56 #370355
by sgtusmc05
bike wont idle was created by sgtusmc05
Hello everyone,
I have a 81 kz440 D2 and just cant seem to get it running right. The problem I have is that whenever the throttle is rolled the bike will die, but if the idle is at 4k when the throttle is rolled the bike will respond well. After the throttle is rolled at 4k, however, the rpms will slowly fall until the bike dies. I have been trying to fix these problems for months, but it never works.
Any help you folks can provide will be truly appreciated, thank you.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
23 May 2010 21:17 #370377
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic bike wont idle
Compression numbers really help!
Roll the throttle on and hold it when it dies.
Then pull the plugs and have a look.
Wet with gas... too rich.
Bone dry... too lean.
You can hook up a timing light to make sure you have consistant spark the whole time.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- sgtusmc05
24 May 2010 08:11 #370440
by sgtusmc05
Replied by sgtusmc05 on topic bike wont idle
Thank you tek9ine I will try it out as soon as possible and will post compression numbers as soon as I can thanks again.
- Thank you received: 2237
24 May 2010 09:14 #370452
by TexasKZ
Replied by TexasKZ on topic bike wont idle
Plugged low speed circuits in carbs?
- sgtusmc05
24 May 2010 10:24 #370467
by sgtusmc05
TexasKZ,
I took the carbs out a couple of weeks ago and cleaned them in depth. I didn't notice anything plugged up though. I will check again though.
- sgtusmc05
24 May 2010 12:24 #370508
by sgtusmc05
Hey guys,
Quick question. I was tinkering with the bike and decided to try and start it without the fuel tank. It wouldn't start so I plugged the vacuum fuel line with my finger after that it started right up and maintained a constant idle speed. Do you guys think that there is an air leak in the petcock. On another note the application of throttle still killed the bike, but could that be because there isn't enough fuel in the float bowls alone to feed the enigine or be cause it wasn't completely warmed up. Could it also be another problem? Any help would be greatly appreciated.
Thanks in advance!!!
