help,carbs?
- b.tracy79kz
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- b.tracy79kz
- baldy110
- Thank you received: 512
- Thank you received: 2098
the vacuum ports are on back of carbs,only two (right).yes they are plugged.
Each carb holder (between carb and engine) has a vacuum port (nipple) used to sync, which is capped (plugged) in normal running.
#3 carb has its own vacuum port (nipple) to afford vacuum to the petcock. A tube connects this port to a nipple on the petcock.
Two vent ports vent the four float bowls to atmosphere, thus preventing "vapor lock" inside float bowls.
Good Fortune.
Note the vacuum to petcock nipple is on carb #2 in this example.
The "T" fitting where fuel line from petcock attaches to carbs is called a "fuel pipe."
Carbs with dual fuel lines from petcock are equipped with two fuel pipes.
[Click on image to enlarge view.]
- b.tracy79kz
