what carbs would work?
- clutch85
20 May 2010 22:29 #369458
by clutch85
what carbs would work? was created by clutch85
i have given up on trying to tune carbs on kz440 with no airbox and have no clue where to find airbox with ALL the parts to it does anyone know what would be a good set of carbs to replace the cv carbs with?
- roy-b-boy-b
- Thank you received: 103
21 May 2010 04:25 #369476
by roy-b-boy-b
Replied by roy-b-boy-b on topic what carbs would work?
Did you jet the bike up ? Sorry if i missed the thread. Roy
- larrycavan
- Visitor
21 May 2010 04:43 #369478
by larrycavan
Replied by larrycavan on topic what carbs would work?
There's got to be a 440 air box sitting around in a salvage yard somewhere. That would be easier and less expensive than replacing carbs.
- mjg15
21 May 2010 05:04 #369485
by mjg15
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Replied by mjg15 on topic what carbs would work?
Ebay ??
I have easily been able to fill nearly my entire garege w/550 stuff from there!!
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- mjg15
21 May 2010 05:11 - 21 May 2010 05:15 #369487
by mjg15
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 21 May 2010 05:15 by mjg15.
- H1Vindicator
- Thank you received: 53
21 May 2010 07:35 - 20 Feb 2013 20:13 #369512
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 20 Feb 2013 20:13 by H1Vindicator.
- ZER
22 May 2010 17:54 - 22 May 2010 17:55 #369906
by ZER
Michigan Yooper
1983 KZ440 LTD Belt Drive,(drag bars, smoothed side covers, shaved seat, pod filters, bar end mirrors) 1981 KZ440 LTD (parts bike)
Replied by ZER on topic what carbs would work?
Have you taken the carburetors apart to see if there is anything clogging up anything.
I just took mine apart today and found the diaphragm had been eaten in one place, where gasoline must have pooled as it sat on the shelf(bleeping ethanol mix). Luckily I have a spare carburetor set that I can steal the diaphragm from.
I used a welding torch tip cleaner that is available at most hardware stores to clean out any debris. About $5-7.00
Michigan Yooper
Last edit: 22 May 2010 17:55 by ZER.
