Keihin CV34 idle screw adjustment?
  • chrispysaki
  • chrispysaki's Avatar Topic Author
20 May 2010 10:06
#369250
Dumb question, but does turning the screw in (clockwise) make it leaner or richer? I was under the impression that turning it in reduced the amount of air that passed through, thereby making it richer, but reading some threads on here, I think it might be the opposite.
Thanks,
Chris
  • JR
  • JR's Avatar
Re: Keihin CV34 idle screw adjustment?
20 May 2010 15:17
#369350
The idle screw would be that big black thumbscrew underneath carbs 2 and 3. If you mean the pilot screws at the top and to the front of each carb then clockwise (in) is leaner and anticlockwise (out) is richer.
I used to have it ass backwards until Tek9ine set me straight and I double cheked mine :)
  • xLowEndx
  • xLowEndx's Avatar
  • Slappa da bass
20 May 2010 16:00
#369360
Newb here but also thanks to JR learned that idle adjustment clockwise raises the RPMs.
1980 Kawasaki KZ750-H1 LTD
20 May 2010 16:16 - 20 May 2010 16:32
#369366
There are four carbs. Each separate carb has a screw to adjust fuel mixture in its pilot circuit, generally called pilot mixture screw. A small flat blade screw driver is used to turn the screw.
The idle adjustment is a different part, sometimes called idle screw, is a knurled thumb screw which raises or lowers the idle speed setting on all carbs, simultaneously. Usually turned by human fingers. It doesn't affect the fuel mixture.
Here's a carb diagram showing the pilot mixture screw. The knurled idle screw isn't shown on this diagram.
Good Fortune! :)
[Click on image to enhance view.]
Last edit: 20 May 2010 16:32 by Patton.
20 May 2010 16:38
#369379
The idle adjustment, sometimes called idle screw, is the knurled thumb screw which raises or lowers the idle speed setting on all carbs, simultaneously. Usually turned by human fingers. It doesn't affect the fuel mixture.
Here's a carb diagram showing the idle screw. The pilot mixture screw isn't shown on this diagram.
  • bsjoker101
  • bsjoker101's Avatar
20 May 2010 19:25
#369417
I was wondering if there was some sort of base adjustment for that pilot screw? I'm pretty sure from what I've read around people have posted that its 2 screws out. However my screws were all corroded up when I removed them so I did not screw in to see I just took them out. By observation of where the screw sat in the hole, they were way farther adjusted out then only 2 screws from the seated position. I'm confused.
1982 KZ750 H3
  • chrispysaki
20 May 2010 22:11
#369455
Sorry, lazy use of terminology. I did mean the pilot mixture screws. Thanks for the answer: counterclockwise = richer.
20 May 2010 22:23
#369457
Most of the time on most carbs ---
A pilot screw on engine side of carb is a mixture screw. Turning in clockwise reduces amount of mixture, thereby leaning. And turning out counter-clockwise increases amount of mixture, thereby enrichening.
A pilot screw on air box side of carb is an air screw. Turning in clockwise reduces amount of air, thereby enrichening. And turning out counter-clockwise increases amount of air, thereby leaning.
Good Fortune! :)
  • JR
  • JR's Avatar
21 May 2010 17:52 - 21 May 2010 18:07
#369654
On the Keihin CV34 the pilot screw is on the top on the engine side of the carbs
Turning out enrichens
Spec for the 750/4 is 2 turns but I have found mine work best at 2 1/2 turns out.
Last edit: 21 May 2010 18:07 by JR.
  • sig
  • sig's Avatar
14 Jul 2013 20:32
#596510
I havea set of these carbs but the screws seem to be covered. Anyone have a suggestion for opening this up?
Attachment CAM00372.jpg not found
1982 KZ650H CSR
  • crh
  • crh's Avatar
  • Banned
  • Banned
14 Jul 2013 20:51 - 14 Jul 2013 21:00
#596512
1/8" drill bit to drill through the plug, then thread in a sheet metal screw and pull the plug out with pliers.
Be careful when drilling the plug that you don't jam the drill bit into the mixture screw. It's possible to have the spinning bit run the screw in tight and damage the tip.
Center punch the plug first using a spring loaded center punch. Drill slow with a sharp bit.
After the plug is out, blow out the well with air to remove metal chips before you turn the mixture screw.
The screw itself is about 1/4 below the bottom of the plug. The plug is about 1/8" thick. I can't emphasize enough how important a sharp drill bit is. Never drill fast...always slow and easy.
IF you remove the screws, there will be a spring, a little flat washer and a tiny rubber o ring on it. The washer and O ring often stick in the carb body and have to be retrieved with a pick. Do not blow air through the passage with the screw removed until you have those parts accounted for.
With today's pump gas, it's every common to have to richen up the pilot fuel screws. On many vintage Honda V Twins, we frequently up the pilot jet one size. If you need more than 3.5 turns out to get the pilot mixture correct, you need a larger pilot jet.
Last edit: 14 Jul 2013 21:00 by crh.
The following user(s) said Thank You: sig
