i need help with 24mm mikunis.
- 4rugrat1
19 May 2010 21:18 #369157
by 4rugrat1
i need help with 24mm mikunis. was created by 4rugrat1
i bought a ks650, it ran fine driving home, i put a v&h exhaust system, and it came with a k&n filter in the stock airbox, so i upped my jets to 107.5 from 97.5, and 17.5 from 15. and now it wont run except on choke, any help or tips would be great, thanks.
- 4rugrat1
20 May 2010 07:35 #369217
by 4rugrat1
Replied by 4rugrat1 on topic i need help with 24mm mikunis.
Air screw setting for this bike would help.
- Bluemeanie
- Thank you received: 14
20 May 2010 13:47 #369330
by Bluemeanie
Replied by Bluemeanie on topic i need help with 24mm mikunis.
Jetting shold be in the ball park. Somehow in the process of jetting you cut off fuel supply as the choke is actually a fuel enricher valve which adds fuel. Either a pinch fuel line or you need to remove (I know, what a PITA) carbs and recheck your work. Check float level and make sure all passeges open. Let us know...
