- Thank you received: 5
need help getting 650 running
- jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- 4rugrat1
- rstnick
- Thank you received: 377
Just swap the green and black coil wires and try to start her.
Just takes a momment and will let you know if it's that simple.
Other wise, are the plugs getting wet with gas?
What's the air filter/s like? Should still sputter with air filter problems though.
Maybe the enricher circuit/choke system is clogged.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- JMKZHI
- Thank you received: 48
This shouldn't be a starting/idle problem, but how about the accelerator pump circuit? That probably was/is clogged. Test by actuating the throttle pulley vigorously - fuel should squirt out the pump nozzles straight back without hitting the carb bore walls.
Did you do the initial mechanical synchronization?
The gap should be about 0.8-1.0mm or thereabouts.
The right side coil should have the red/black igniter leads & the 1-4 spark plug wires connected to it.
The left side coil should have the green/black igniter leads & the 2-3 spark plug wires.
Did you check/lubricate the timing advancer?
- 4rugrat1
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- Thank you received: 2098
We threw a set of carbs from a running 650 on and got the same results. Not even a pop. I was beginning to lose hope on this bike and just sat and held the starter button for a very long time. After a while it popped, slowly kept getting better then it ran. Not only did it run but it ran great. We let the bike warm up, and put the original carbs on and it also ran and started good. I'm happy that its running and ready to go back to the owner but it really bothers me that it started so hard the first time and made no attempt to start before but all of a sudden starts/runs fine now
Perhaps a slower than normal fuel supply through a partially blocked petcock took longer to initially fill the dry float bowls.
If this is the case, fuel flow may still be slower than normal. Just not so readily apparent once the float bowls are full, with reduced flow being enough to keep them full.
A dirty in-line fuel filter could cause the same thing.
- baldy110
- Thank you received: 512
