jetting 29 smooth bores
- rob220
18 May 2010 19:06 #368873
by rob220
1975z1 w 80 front end
1075kit
29 mikuni smooth bores
vance comp 4n1 header
stretched 6 inches w/double clubfoot swingarm
suzuki tl1000 rim
jetting 29 smooth bores was created by rob220
I just put my motor back together it has a 1075kit in it.The
head has been ported,polished,bronze guides,under bucket shims,and the cams are bigger(cant remember what kind or size).I'm running 29 mikuni smooth bores and an open Vance and Hines header.I'm currently running either 117.5 or 120 main jets and cant remember what size idle jets.What would be a good size jet combo to run(unless the 120's are o.k.).
1075kit
suzuki tl1000 rim
- rob220
18 May 2010 19:08 #368875
by rob220
1075kit
suzuki tl1000 rim
Replied by rob220 on topic jetting 29 smooth bores
And do I need to adjust my needles if possible?
1075kit
suzuki tl1000 rim
- PLUMMEN
- Thank you received: 104
18 May 2010 19:31 #368890
by PLUMMEN
Replied by PLUMMEN on topic jetting 29 smooth bores
try running it first to see how it runs,no 2 bikes are the same
- timebomb33
18 May 2010 19:36 - 18 May 2010 19:39 #368896
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic jetting 29 smooth bores
on the street with a 1075 kit ported head and decent cams i use either 117's or 120 depending on the time of year and i use 20 pilots i put the needles in the center position. works very well for me so i'm not changing unless needed by the way where i live and ride mostly is around 2200 ft of elevation if your closer to sea level you may have to richen up your mains a bit. and by the way no matter what some boneheads on here act like there are some people on here that know our stuff and have had alot of experiance as well
Last edit: 18 May 2010 19:39 by timebomb33.
- rob220
18 May 2010 19:37 #368900
by rob220
1075kit
suzuki tl1000 rim
I ran it a little but not much.Idle was a little rough mid seemed fine and didn't really get to get on the high end.It's been raining all week and will be until fri or sat.
1075kit
suzuki tl1000 rim
- mtkawboy
- Thank you received: 16
18 May 2010 19:44 #368908
by mtkawboy
Replied by mtkawboy on topic jetting 29 smooth bores
Mine is an 1105, 10.25 - 1 with a ported head, 395 lift 260 degree cams & I run 20 pilots, 120 mains & needle in the center. Mixture screws about 1/2 turn out at 3750 ft altitude
- rob220
18 May 2010 20:02 #368918
by rob220
1075kit
suzuki tl1000 rim
Seems that the 120main are fine and I'm gonna go to 20 pilots.I think I have 17's now.Adjust the needles to the center and see how she runs then.
thx for all input.
thx for all input.
1075kit
suzuki tl1000 rim
- Thank you received: 2098
18 May 2010 21:24 #368929
by Patton
Replied by Patton on topic jetting 29 smooth bores
Here's a link to info from Z1E
www.z1enterprises.com/reference/z1-carb-guide.aspx
Which includes the following:
Below is a reference of jet settings for the 29mm carb on Z1 / KZ engines. This is a good starting point for a bike with 4-1 exhaust, after market cams (up to 0.410" lift) and high compression pistons (approx 10.5:1). Each bike setup is different, so actual settings will vary.
29mm smoothbores Z1 / KZ900 / KZ1000
Main Jet 120
Air Jet 0.9
Needle Jet O-6
Jet Needle 5DL31-3
Throttle valve (slide) 1.5mm cutaway
Pilot Jet 17.5 or 20.0 (or 25 in the later versions)
Air Screw setting 1 1/2 turns out
Main Jet 120
Air Jet 0.9
Needle Jet O-6
Jet Needle 5DL31-3
- rob220
19 May 2010 20:39 #369146
by rob220
1075kit
suzuki tl1000 rim
Thanks for the link. I rode it a little bit today but didnt make any adjustments yet. It's running good but it can run better. I checked and the cams are webcams 425 lift 260degrees. Once I get a chance I will try to post a video of it running.
1075kit
suzuki tl1000 rim
