- Thank you received: 1
KZ 750 with pods and V&H jet question
- Ituen
- Rider
18 May 2010 04:22 #368685
by Ituen
1982 KZ750 E
Kawasaki Rider
KZ 750 with pods and V&H jet question was created by Ituen
I'm rebuilding the Keihin carbs on my 82 KZ 750 with pod air filters and a Vance and Hines exhaust. What size jets should I use for this combo? (I will be tuning it on a dyno once I get my cylinder head back from LarryC).
1982 KZ750 E
Kawasaki Rider
- chrispysaki
18 May 2010 12:52 #368784
by chrispysaki
Replied by chrispysaki on topic KZ 750 with pods and V&H jet question
I have an '80 750-4 with pods, 4-1 Kerker and GPZ cams. I was using 68 & 130 jets, which I think are two or three sizes up from stock. It was running way too lean with those, so I just ordered 72 and 140 today from Z1. I'm also planning on doing some mild porting, so I wanted the new jet sizes to account for that as well.
- Ituen
- Rider
18 May 2010 16:33 #368818
by Ituen
1982 KZ750 E
Kawasaki Rider
Replied by Ituen on topic KZ 750 with pods and V&H jet question
I'm probably better off purchasing a Dynojet Stage 1 & 3 jet kit and playing around with the jets while on the dyno.
1982 KZ750 E
Kawasaki Rider
- timebomb33
- Thank you received: 10
18 May 2010 16:58 #368820
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic KZ 750 with pods and V&H jet question
sounds like a good plan to me thats what i would do my self they have the proper needle sizes all ready figured out for you it will definitly save you a bunch of time and energy.
- JR
- Thank you received: 449
18 May 2010 18:07 #368847
by JR
Replied by JR on topic KZ 750 with pods and V&H jet question
I like 70 and 140
Not ported
Not ported
- Ituen
- Rider
18 May 2010 19:14 #368878
by Ituen
1982 KZ750 E
Kawasaki Rider
The Dynojet Stage 1 & 3 kit (#2102) comes with 116, 122, 130 and 136 jets. I can buy other sizes if any of these jets don't work.
1982 KZ750 E
Kawasaki Rider
- timebomb33
18 May 2010 19:25 - 18 May 2010 19:32 #368884
by timebomb33
dyno jet jets are not the same size as keihin or mikuni so you cant go by that just set the carbs up according to the instructions and you should be good to go. for instance a 122 dj is the same as a 130 keihin and a 115 mikuni a 136 dj is the same as a 148 keihin and a 127.5 mikuni so as you can see there is quite a bit of difference.
Last edit: 18 May 2010 19:32 by timebomb33.
- Ituen
- Rider
19 May 2010 03:38 #368937
by Ituen
1982 KZ750 E
Kawasaki Rider
I wasn't aware of the different sizes from different jet makers. Maybe I should just stick with Keihin jets.
1982 KZ750 E
Kawasaki Rider
- timebomb33
19 May 2010 07:47 #369002
by timebomb33
just get the dyno jet kit you will be the happiest with it. install it according to your combo and it will work well.
