- Thank you received: 1
Keihin CV34 pilot screw re-assembly?
- polkat
17 May 2010 14:39 #368564
by polkat
Keihin CV34 pilot screw re-assembly? was created by polkat
Just double checking this as I'm assembling my carbs today. The pilot screw is assembled with the spring first, followed by the little washer, then the O ring last...right? Not the O ring, then the washer...right? Thanks!
- TeK9iNe
- What did you do!?!
- Thank you received: 28
17 May 2010 15:47 #368574
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Keihin CV34 pilot screw re-assembly?
What is the bike?
You could add it to your profile info...
Then I can get you microfiche diagrams.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- JR
- Thank you received: 449
17 May 2010 18:37 #368628
by JR
Replied by JR on topic Keihin CV34 pilot screw re-assembly?
Hi Polkat
Thats it
Screw - spring - washer - O ring. The O ring is last.
I think your bike is the same as mine. 1980 750/4 If ever in doubt go to kawasaki.com, Owner info, parts diagrams, select year as 1982 (trust me) and the rest is easy.
Good luck
Thats it
Good luck
