KZ900 stuck throttle
- bino
17 May 2010 13:20 #368547
by bino
KZ900 stuck throttle was created by bino
Hello all,
My Kz900 throttle is stuck. I twist the throttle and it only moves approx 1/2 inch. Bike has been laid up for 9 months. Thanks in advance.
Bino
Bino
- polkat
- Thank you received: 1
17 May 2010 14:55 #368566
by polkat
Replied by polkat on topic KZ900 stuck throttle
Try reaching in and moving the cable bracket at the carbs. If that moves okay then it's the cable(or bales if there's two). If it didn't get pinched somewhere, it may be a problem in the handlebar mechanism. I've had one jump out of the groove they ride in and jam up the grip tight.
