Clear Tube Method question
- Nats82
16 May 2010 09:01 #368263
by Nats82
Clear Tube Method question was created by Nats82
Hi Forum,
When checking fuel level when using the tube, and with the measurements 2.5~4.5 Must they all be dead on center ie. I'm guessing that they are high low numbers? One might be at 2.5 the other at 3.5? hope I'm making sense! any help would be great, thanks forum
- Thank you received: 2098
16 May 2010 09:20 #368267
by Patton
Replied by Patton on topic Clear Tube Method question
The closer the better.
Would suspect otherwise equal carbs to have slight differences in fuel mixture throughout the throttle range, which to the rider may be virtually unnoticeable.
If fuel levels range between 2.5mm and 3.5mm among the four carbs, and the bike is performing well, I wouldn't go the trouble of attempting exact perfection.
Opinions on this may differ.
- Nats82
16 May 2010 09:32 #368270
by Nats82
Replied by Nats82 on topic Clear Tube Method question
Thanks patton,
Thats what I was kind of thinking, I'm in the middle of this right now, and also read some older threads, there is some difference in opinions, but they don't vary much, so thanks again!
