What Carb is this (and how to get them working)
- hocbj23
- Visitor
- Sircraigery
My floats were wayyyy to low (aka barely any fuel in bowls), so that explains why a richer mixture (with the choke) caused it to rev higher.
Just an idea, it worked for me. The only problem is, I can't get these things to stop leaking fuel. I am using an after market petcock, not a vacuum type so I think that is my problem.
- Thank you received: 2098
...choke will not cause the engine to rev higher (it actually bogs it, like it should)....
Actually, both Z1 and KZ900 when brand spanking new and cold cranked with full choke, would soon over-rev if not carefully attended to reduce choke as needed to prevent over-revving.
That's the way they're supposed to be. Just the nature of the beast.
Of course, at warmer engine temps, too much choke is expected to cause bogging.
- kusanagi
- Thank you received: 1
how are u trying to start it.Best way is to open petcock,turn switch on,pull choke out and hit the starter button--keeping hands OFF the throttle.If u so much as look at the throttle when trying to start my kz,shesa no start.???bj
Thanks for the input. I do not use any throttle as it will ruin the vacuum. But thanks anyway!
- kusanagi
Mine was the same way. All I did was adjust my float height, and it starts much much easier now. And now, my choke will not cause the engine to rev higher (it actually bogs it, like it should).
Hmm, could be an idea. Measuring floatbowls is with a tube isn't it?
Height should be around.... ?
Adjustment can be made by....?
Thanks in advance for the extra intel!
- kusanagi
They will probably arrive next week (when I am at Silverstone,UK with the Ducati)
Let's wait and see!
- Sircraigery
- Koda1
I would suggest having your carbs professionally cleaned and rebuilt. I sent my set to a guy who specializes in servicing Kawasaki carbs. My set came back looking brand spanking new… and after installing them on my '82 KZ 750, the bike ran like a dream. Wired George does top notch work. It may take awhile, but well worth the wait!!! You can find him by going to this website. www.wgcarbs.com
Good Luck!!
'78 CB750K
'82 650 Nighthawk
'82 KZ750
"The problem with socialism is that you eventially run out of other peoples money"
M. Thatcher
- Jeff.Saunders
You need to make sure the carb holders match - otherwise the carbs will either distend the rubber and split it, or the carbs will not stay located in the carb holders when you tighten the clamps.
www.z1enterprises.com
Z1 Ent on Facebook,
- kusanagi
Check your carb holders to make sure they match the carbs. When you look at the carbs, you we see a groove cut around the spigot that goes into the carb holders. On the inside of the carb holders there is a rib that should locate perfectly in that carb groove. There are two different types of groove - a triangular 'wedge' cut (with is what appears to be on your carbs, and a rounded groove.
Thanks for the heads up on this! Will keep an eye on it when they arrive and before I try to install them
- kusanagi
Hey there,
Good Luck!!
Hi Koda1, I know Wired George and heard some good stories. But I am not in the US, that makes it maybe a bit more complex although shipping should be possible.
Maybe I will give the spare set a go. Then the wait shouldn't be a problem, only the money is
- kusanagi
Yeah, a clear tube off the drain plug (not overflow) will tell you how high the fuel level is. Patton helped me out with that one, it's in my vm24 thread. All the setting on the first page of that thread are updated - but your carbs are probably different. There are pic on there to show you what mine look like.
OK, will have a look at your thread when I am back from the UK.
Will be a busy week, testing out the floatbowl height and testing the other carbs also.
