Float level check question
- 1982kz440ltd
15 May 2010 20:13 #368196
by 1982kz440ltd
1982 KZ440 LTD D4
Float level check question was created by 1982kz440ltd
Where should I be holding the clear tube to check float levels? At the red line? Or towards the engine or airbox?
1982 KZ440 LTD D4
- Link14
- Thank you received: 6
15 May 2010 20:18 #368198
by Link14
Replied by Link14 on topic Float level check question
Looks good at the red line
- cardinal
15 May 2010 20:20 #368199
by cardinal
Replied by cardinal on topic Float level check question
I would try getting the carb totally vertical instead of sloping like it is in your pic. If the float bowl is flat, it shouldn't matter where your tube is...
I'm new to this, but that's what makes sense to me.
- JR
- Thank you received: 449
15 May 2010 20:52 #368206
by JR
Replied by JR on topic Float level check question
Looks like a very clean motor - at least from the small section in the photo.
I vote for red line
You might be interested in www.kz400.com/ which has tons of info on the 400 and 440 and was set up by Odd Ivar Bekelund a member here who passed away a few years ago.
I vote for red line
