mikuni bs34's
- ccentralm
15 May 2010 16:30 #368148
by ccentralm
1982 Kawasaki KZ 750LTD. i wanted the big boy 1000, but there's like a billion of these 750 ltds running around. so what the hey!
mikuni bs34's was created by ccentralm
hey gang,
wondering where i can get mikuni bs34 bowl drain screws. the motorcycle shop i paid money to have my carbs cleaned actually just damaged them and took my money! so, it's going to be done by me this time. it you want something done right...anyways, any advice or links will be appreciated. thanks in advance!
- Motor Head
- Thank you received: 391
15 May 2010 17:02 #368154
by Motor Head
Replied by Motor Head on topic mikuni bs34's
92009-1095
Should be MaKaw #
Any dealer or online OEM parts source should be able to order them, $6-7 ea.
Should be MaKaw #
- ccentralm
15 May 2010 17:10 #368155
by ccentralm
Replied by ccentralm on topic mikuni bs34's
awesome! thank you.
- ccentralm
15 May 2010 17:12 #368156
by ccentralm
btw do these bikes use 12mm speedo cables? you can't use dirt bike speedo cables can you?
- Motor Head
15 May 2010 17:19 #368157
by Motor Head
Got no Idea, but this link has the Kawasaki parts diagram for your model:
www.cyclepartsnation.com/pages/parts/viewbybrand/parts.aspx
Then once you get the part # for the part you want, shop around for price and availability.
- ccentralm
15 May 2010 17:27 #368160
by ccentralm
thats good info, the only problems is im working with something a little different from stock. i put a gpz dash on a kz ltd. the gpz dash sits higher than the kz dash, so im not quite sure how i should shop for a cable. im a little stuck on what overall length and housing length to choose from on denniskirk.
- Motor Head
15 May 2010 17:39 #368166
by Motor Head
Do have the stock cable, then measure the overall length + the additional length to get up to the new height. And you could test the fitting onto the GPZ speedo head. If Dennis is where you want to order they have a quite good technical service, give them a call for questions.
- ccentralm
15 May 2010 17:49 #368168
by ccentralm
is it necessary for droop in the cable. most cables have some play so they aren't pulled tight, im guessing so you can turn the bars on the bike.
- roy-b-boy-b
- Thank you received: 103
15 May 2010 17:55 #368169
by roy-b-boy-b
Replied by roy-b-boy-b on topic mikuni bs34's
