'80 KZ 440 vacuum piston diaphragm repair?
  • cardinal
  • cardinal's Avatar Topic Author
15 May 2010 15:05
#368142
Last year I was experiencing some pretty bad running conditions, hard starting, stalling, running pretty rough in general. I decided to get the bike back on the road and thought I'd start with a fuel system clean up. After opening the carbs I found a nice tear in the vacuum piston diaphragm. Called up the local shop and it's a $250 part! I did a little searching online and found it for a bit less than $200, but it's still way too much for this cheap old bike. Checked on ebay for a junker set to pull apart, but it looks like the 440 was only offered for a short run and there aren't a lot of them out there.
I was wondering if anyone has ever successfully repaired a tear in that diaphragm? I know it's a long shot and may not be a good long-term fix... any other ideas for finding a old weird part like this? I could spend $50. But much more than that is to much.
The carbs are keihin and they have 1241 and SA25 stamped on them. Any help is appreciated greatly.
  • Motor Head
  • Motor Head's Avatar
Re: '80 KZ 440 vacuum piston diaphragm repair?
15 May 2010 17:25
#368159
16126-1044 $160 + freight if still available from Kawasaki. Maybe cheaper from the right source. I've seen some companies stating they will rebuild/ install new rubber on your slide. Also K&L makes the replacement part for some models, yours?
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
15 May 2010 18:05 - 20 Feb 2013 20:12
#368171
Last edit: 20 Feb 2013 20:12 by H1Vindicator.
  • Link14
  • Link14's Avatar
15 May 2010 18:27
#368174
My '79 kz400 had Keihin CV34 carbs with the diaphrams (looks like your picture). My '82 kz750 Ltd has the same CV34 carbs...just 4 instead of two. I had problems with my kz400 and it turned out to be the diaphram. The PO had tried to repair the tear, but it didn't work. Went to a bone yard and got one for $30.
Good luck.
  • cardinal
15 May 2010 19:34 - 15 May 2010 19:38
#368186
Good luck.
Thanks for the ideas. Is there some way to find out what carbs I have and what other bikes out there have the same?
I measured the diameter of the diaphragm at 68mm. The engine side of the carb is 36mm ID. I'm assuming CV34 means it's a 34mm carb?
Last edit: 15 May 2010 19:38 by cardinal. Reason: having problems attaching pictures
  • cardinal
15 May 2010 19:39
#368188
A better view of the top of the carb.
  • JR
  • JR's Avatar
15 May 2010 20:58
#368207
Contact Wiredgeorge at wgcarbs.com
I think he may be able to fix.
  • loudhvx
  • loudhvx's Avatar
15 May 2010 22:53 - 15 May 2010 22:57
#368210
No eBay APP ID and/or Cert ID defined in Kunena configurationThese were going for $40 a pair back in March. Have to get parts in winter to get a deal, now everybody wants to fix their bikes so the price has skyrocketed. There are at least two other places with these rubber diaphragms. One is in Germany, and I think the other is in Britain.
Check out the KZ400 twins forum. There is a sticky thread about this subject with a lot of details.
www.armbell.com/kz400/viewtopic.php?t=3172&mforum=kz400
In this auction, there are photos of how to change the diaphragms.
Last edit: 15 May 2010 22:57 by loudhvx.
  • cardinal
17 May 2010 01:13
#368448
Thanks for the help. I decided that I'd wait till the prices come down in the winter. I was at a bbq tonight and had a few beers with some of my bicycle friends and one of them asked "Why don't you just patch it with a tube patch?"
I thought that was a brilliant idea, so I tried it. Had to chop a patch in half, but it looks good! The seal is great, I'll fire it up tomorrow and give a report.
Am I stupid for trying this? I really don't have a lot of experience with this kind of stuff, but a bike tire tube patch is about $1 and the replacement diaphragm is about $180.
I figure it's worth a shot.
  • cardinal
17 May 2010 01:17
#368449
Here's a pic of the patch job.
  • JMKZHI
  • JMKZHI's Avatar
17 May 2010 08:21
#368502
Others have mentioned using polyurethane glues - usually "ELMERS PROBOND" Polyurethane Ultimate Glue or Gorilla Glue polyurethane glue.
Here's a quote from a CV diaphragm repair topic:
On the third try, and after reading some industrial adhesives literature, I came accross a family of adhesives that include regular super glue, and polyurethane adhesives. You may know the polyurethane adhesives under "Gorilla Glue" or Elmer's "Probond". These guys have di-isocyanates in them and can be particularly nasty, but cyanoacrylates and di-isocyanates are one of the only suitable bonding materials for nitrile rubber, or even hydrogenated n butyl rubbers (the green o rings used in r134 ac systems). And speaking of HNBR (the green rubber), I wish people would push keihin and mikuni and the like to use that stuff in carbs. When you look at what they resist and the temps and pressures they resist, they are CLEARLY the choice for using in a casty gasoline / solvent environment especially where there is heat involved.... But I digress. So gorilla glue is your best bet. Superglue cures too stiff, and will degrade over time with humidity (crazy huh?). The gorilla glue, being a polyurethane and using the chemicals it does to react with the bonded surfaces, won't let go even when covered with gasoline or carb cleaner. It remains somewhat flexible, but of course is much stiffer than your diaphragm which is just a nitrile rubber coated cloth. You can apply it thinly over tears and cracks and holes and it's not going to let go.
  • bountyhunter
  • bountyhunter's Avatar
17 May 2010 12:33 - 17 May 2010 12:35
#368541
Somebody on ebay was selling new rubbers for the 400/440 bikes a while back for cheap price (like $40)
I patched slits in mine with that urethane glue. Lasted a while.
Last edit: 17 May 2010 12:35 by bountyhunter.
