Carb Questions.
- DestroyKC
1980 KZ650 E1 LTD (CHOPPED)
- DestroyKC
- Thank you received: 2098
Hey I have a few questions. I just competely rebuilt my carbs off my 81 kz 650. and replaced the fuel lines that were already there. so, what are these nipple things supposed to be connected to i circled them in red..... pods are on the bike btw.
This may help.
- DestroyKC
oh. and the black tubes that i connected to the carbs where they were when i got the biek...and i traced them back and they are connected to this ugly ass thing.. what is this? a breather thing? do i need it?
If that's a filtered intake for the two reed valve caps, may toss it, and connect the caps to each other with a hose between them (as shown below in red), or just block off each cap. The caps allow for air injection into the exhaust to help reduce exhaust pollution.
- JMKZHI
- Thank you received: 48
The top brass nipple in the first photo is the vacuum port for the petcock. Engine vacuum pulls open a diaphragm to allow fuel to flow by gravity. When the engine is off, a spring returns the diaphragm to the closed position to stop the flow of fuel (ON & RES).
PRI (prime) bypasses the diaphragm to allow fuel to flow - engine on or engine off.
The bottom brass nipple on the accelerator pump (1st pic) is a fuel supply line for the accel pump circuit. See carb photo/diagram above. It would be a good idea to test the functionality of the accelerator pump.
Also in the 1st photo, the black tubing is a vent. Those two should be routed over the airbox shoulders then snug fitted between the airbox & sidecovers. The left side has a tubing clamp on the frame. They should point down to keep water out of the carburetors.
The carb overflow tubing & battery vent tubing should be routed behind the engine but forward of the swingarm & away from the chain.
If the airbox is not installed, a filter similar to the one in the 2nd photo should be installed on the crankcase breather.... it's the ~4" round thing above the engine/transmission & kinda below the carbs. If no airbox, note what size the main jets are, then check to see if they are suitable for your air-filter/exhaust setup.
