poping from intake
- wes_scooter
14 May 2010 15:32 #367954
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
poping from intake was created by wes_scooter
my 76 kz900 is poping out of the intake, and has a bad miss if held at a steady rpm around 5k or so. checked compression and its 130 on all 4. plugs are sooty black. timing is electronic and spot on. had the engine apart last fall repairing bent valves from previous owner. plugs make me think its rich. but that dosent explain the intake poping. i sitll have to check my valve lash again. any other things that might be causing my troubles. thanks.
76' kz900
70' yamaha R5
2006 wr450f
- Motor Head
- Thank you received: 391
14 May 2010 16:25 #367965
by Motor Head
Replied by Motor Head on topic poping from intake
While in the valves double check the cam shaft timing. Then I would make sure of having proper Ignition spark.
Then it would have to go to the carbs/ fuel delivery, recheck float levels, sync, etc.
