IS THIS BAD?
- jonnygorman
14 May 2010 15:16 - 14 May 2010 18:11 #367950
by jonnygorman
IS THIS BAD? was created by jonnygorman
Noticed this during carb rebuilds.The red dotted line shows the outline of where the aluminum cast is supposed to be, the black dot is the float pin, the purple outline is the jb weld (which now holds one side of the pin in place) and the blue arrow is the metal tab on the float which usually bumps up agains the aluminum cast to stop the float from flipping all the way back. P.O. must have snapped it off while trying to remove pin. IT WAS NOT ME! Anyway, is this going to cause a problem for setting float height or do I just bend the center tang which holds the float needle and not the metal tab which stops the float from flipping all the way back. While we are on the topic, my Clymer manual doesn't mention initial butterfly clearances for bench synching and also seems to omit initial rough settings for floats before wasting my life messing with gasoline levels.
I would appreciate any help. Thanks
Jon (sorry see additional post for pics)
Last edit: 14 May 2010 18:11 by jonnygorman.
- jonnygorman
14 May 2010 18:12 #367987
by jonnygorman
Replied by jonnygorman on topic IS THIS BAD?
- Motor Head
- Thank you received: 391
14 May 2010 18:17 #367990
by Motor Head
Replied by Motor Head on topic IS THIS BAD?
Might be worth getting a used carb and putting your jets in it.
- muddy1
- 1980 Kz1000 LTD B4
14 May 2010 18:17 #367991
by muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
Replied by muddy1 on topic IS THIS BAD?
I would replace the single carb with a replacement, jb weld does not belong in your carburetor.
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- keith1
- Thank you received: 2
14 May 2010 18:33 #367993
by keith1
Replied by keith1 on topic IS THIS BAD?
any idea how old that jb weld patch is?....i ve heard arguments from both sides as to wether jb holds up to gas....if its been years and you can verify it, its business
as usual......
as usual......
- Thank you received: 2098
14 May 2010 19:27 #368012
by Patton
Replied by Patton on topic IS THIS BAD?
Here's a link to a good earlier KZr thread on this topic. Includes wg's repair method, alternate products, epoxies, etc.
Bottom line being okay to repair float tower with JBWeld or similar type product and expect to last for many years if done correctly.
Click > Repair broken float tower
- testarossa
- Thank you received: 82
14 May 2010 19:31 #368013
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic IS THIS BAD?
Put me down on the side that says jb weld won't hold up in gasoline. It is essentially epoxy with metal filings suspended in it. Epoxy is not gasoline resistant. I personally would replace that carburetor.
2004 ZX-10R
Angola, IN
- jonnygorman
15 May 2010 09:08 #368099
by jonnygorman
By the way things look inside, I would guess it has been there for a while. Judging by testimony, if it will give me a year or two at the most it is worth it. I need to get the bike back on the road and will just check it now and then until I have the time to find and change the carb. My main question now is, do i need the tower present in order for the float to function properly, or am i ok as long as the pin stays secure? The tower piece has probably been sitting in a landfill for 10 years. Either that or it is still stuck underneath the floor board of the previous owner's garage.
Thanks
Jon
Thanks
Jon
- timebomb33
- Thank you received: 10
15 May 2010 09:17 #368100
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic IS THIS BAD?
a friend of mine broke a post on one of his lectron race carbs a few years back it was either jb weld it or throw it away. we did the jb weld thing and he is still using that carb just about 10 years later so i,d give it a try my self. by the way i have used automatic center punches for years to drive out float pins lots of people that use hammers and pin punches will from time to time break towers off but i never have, knock on wood.
- mark1122
- Keep twisting it
- Thank you received: 109
15 May 2010 09:34 - 15 May 2010 09:40 #368101
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic IS THIS BAD?
This is a very common issue. u must support the leg while driving out the pin.
i have a repaired tower in my rs34 carbs now. i tried JB weld and ran it for a year. after inspection i found the JB was starting to deteriorate . i removed the JB and replaced it with a similar product specifically made for gas tanks. u can get it at any auto supply store.
as long as the pin is supported , u are good to go .just adjust the float level , by bending the center tab , carefully)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 15 May 2010 09:40 by mark1122.
- anarki650
- Thank you received: 5
15 May 2010 10:37 #368111
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic IS THIS BAD?
What type of carbs are those? I've got a couple of extra floats that'll fit vm24, 26, or 28 carbs (assuming the 28s use the same floats as 24 and 26s). PM me if you need one.
09 Kawasaki ER6n
Omaha NE
15 May 2010 10:37 #368112
by Patton
For more repair success stories,
click > kzrider.com/index.php?option=com_kunena&...d=3&id=258976#259079
