BS34 on KZ1000A1/stock airbox/4-1
- Zthou1977
14 May 2010 06:44 #367852
by Zthou1977
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
BS34 on KZ1000A1/stock airbox/4-1 was created by Zthou1977
On my soon to be resurrected Z1000A1 I want to run BS34 carbs from a later LTD. Everybody seems to run this combo with pods, which is not surprising as the boots won't fit. I am planning to use the stock airbox and modify it for the larger carb intake boots. What I am trying to find out is: what is the correct pilot jet / main jet / jet needle combo for such a setup? Any ideas?
PS: Did a search but couldn't find anything.
- otakar
14 May 2010 06:51 #367853
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic BS34 on KZ1000A1/stock airbox/4-1
I would stay with the stock jetting for the later KZ1000M1 (CSR) bikes 37.5 pilot and 122.5/125 main.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Zthou1977
14 May 2010 07:04 #367854
by Zthou1977
Replied by Zthou1977 on topic BS34 on KZ1000A1/stock airbox/4-1
otakar wrote:
BTW: I forgot to include some info on the engine. It will be getting a set of 1015 Wiseco pistons with a CR of 10.25:1. I imagine that I won't need to rejet?
Great! I was hoping it would be a straight bolt-on (apart from the actual fitment of course). Tomorrow I will check the jetting of the carbs, do a cleanup and after that the Dremel will be put to good use on the airbox.I would stay with the stock jetting for the later KZ1000M1 (CSR) bikes 37.5 pilot and 122.5/125 main.
