Carb hoses hook up?
- polarbear
12 May 2010 11:04 #367452
by polarbear
Carb hoses hook up? was created by polarbear
Hello,
New member here. Picked up a 1983 KZ550 ltd with driveshaft a few months ago and I'm in the process of getting it ready to get back on the road (parked for 10 years). It's in good to average shape, with the tank being a bit beat up: paint flaking a bit and one dent.
I've cleaned the carbs, and can't remember/figure out how to hook up a couple of fuel lines.
The ones at the very bottom of each bowl are for overflow and just face down the ground. The one just above is the main fuel line and hooks up to the tank, right?
There is two small rails, one attaches to carb 1-2 and the second one to carb 3-4, about 6inches long, but I just can't figure out what they do or where they hook up?!?
You'll have to forgive me for not using proper terminology, I'm not a mechanic... obviously.
Any help would be appreciated. Thanks!
Christian
Christian
- TeK9iNe
- What did you do!?!
- Thank you received: 28
12 May 2010 15:05 - 12 May 2010 15:09 #367511
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Carb hoses hook up?
Hope these help
If you need more, just ask.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 12 May 2010 15:09 by TeK9iNe.
- TeK9iNe
12 May 2010 15:06 - 12 May 2010 15:09 #367512
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
12 May 2010 15:06 - 12 May 2010 15:09 #367513
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
oops, goofed.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
12 May 2010 15:10 #367515
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
12 May 2010 15:10 #367516
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- polarbear
12 May 2010 16:01 - 12 May 2010 16:02 #367530
by polarbear
Replied by polarbear on topic Carb hoses hook up?
Hey TeK9iNe,
Yup, they help. Thanks for the pics, these are great. It is the part #92059 and #92059A in that last pic that I can't seem to remember where to hook up. By this I mean that I can plug them back on the rail of the carb (as shown in pic), but where does the other end go? In the air box?!?!? Any idea??
Thanks,
C
Thanks,
C
Last edit: 12 May 2010 16:02 by polarbear.
- polarbear
12 May 2010 22:27 - 12 May 2010 22:42 #367601
by polarbear
Last edit: 12 May 2010 22:42 by polarbear.
- TeK9iNe
14 May 2010 19:17 #368007
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
You have a single primary fuel rail (the lower/larger bridged hoses).
The ones you highlighted that are on the smaller/higher rail are carb bowl vent tubes, and yes, they usually connect to two small nipples on the stock airbox.
Your first picture is correct for a vacuum operated petcock setup, which is what that line connects to.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- polarbear
15 May 2010 23:16 #368212
by polarbear
Thanks man, I appreciate the help.
C
C
