kz1000 ltd carb help
- xxsierraxx
11 May 2010 15:20 #367286
by xxsierraxx
1979 KZ1000
1981 CSR 650
Honda "cough"
kz1000 ltd carb help was created by xxsierraxx
I have recently picked upa 1979 KZ1000 LTD. It's a great running bike other than some carb issues. The problem I am having is that the rpms won't come down when i back throttle off. I can rev bike to 3-4000 rpm and back throttle off and rpms remain high. I have to hit throttle a couple times ant they will eventually come down. I diconnected cables and got same results. Checked carb mounts for air leaks, lubed vacuum advance, cleaned idle pilots etc. Checked accelerator pump diaphrams and they are great. The throttle is returning to idle screw completely and still rpms are high. It's worse when the engine is hot. I was thinking maybe a needle is sticking or a slide or two. If they where, would the throttle still return to bottom? It doesn't take much twist in throtttle to get the rpms to 3000 or so, so maybe the slide hang up is very slight. Any suggestions would be appreciated.
1979 KZ1000
1981 CSR 650
Honda "cough"
- hocbj23
- Visitor
11 May 2010 15:49 #367296
by hocbj23
Replied by hocbj23 on topic kz1000 ltd carb help
with the bike not running,twist throttle open and release.U should hear an audible click when the cable bottoms out and the slides close.If not something is hanging up,cable or the carb slides.bj
- keith1
- Thank you received: 2
11 May 2010 16:10 #367298
by keith1
Replied by keith1 on topic kz1000 ltd carb help
pods? pipe?....i doubt highly the slides are sticking as they are bolted to throttle shaft...if the spring is connected and yanking everything back,they are coming back whether they want to or not.....sounds lean....just my ramblings.....
- roy-b-boy-b
- Thank you received: 103
11 May 2010 16:13 #367299
by roy-b-boy-b
Replied by roy-b-boy-b on topic kz1000 ltd carb help
Do your carbs leak gas? Roy
- xxsierraxx
11 May 2010 19:36 #367346
by xxsierraxx
1979 KZ1000
1981 CSR 650
Honda "cough"
Replied by xxsierraxx on topic kz1000 ltd carb help
No gas leaks, tried with cables on and off and either way throttle always snapped back, I can hear it hit bottom and see it hit idle screw. I even had idle circuit screws running a bit on the rich side with no change. So much so that exhuast was getting quite black. Maybe I need to tear these carbs down and rebuild them. Might see something on the bench that I can't see on bike. Very wierd issue.
1979 KZ1000
1981 CSR 650
Honda "cough"
- TeK9iNe
- What did you do!?!
- Thank you received: 28
11 May 2010 19:48 - 11 May 2010 19:54 #367348
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic kz1000 ltd carb help
It's your ignition advancer!
Pull of the ignition cover, and then the ignition plate (after marking its location on the screws).
Unscrew the small bolt on the shaft and remove the advancer cam from the spring weights/arms. Clean the shaft and the cam inside with some metal polish very lightly. Then spray clean with carb/brake cleaner.
Coat both with light oil, like sewing machine oil and re-assemble.
Even though it may feel as though its returning properly, it must be very well oiled and clean, as once hot it can start to stick very easily!
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 11 May 2010 19:54 by TeK9iNe.
- Thank you received: 2098
12 May 2010 03:21 #367380
by Patton
Replied by Patton on topic kz1000 ltd carb help
If not already done, with engine running, would spray copious amounts of WD40 all around carb holders and vacuum plug caps.
Ingestion of the WD40 through an air leak should cause noticeable smoke from the exhaust.
Although an unlikely suspect, would also assure enrichener circuit is fully closing when the choke lever is pushed down to the off position. Could check operation of the choke shaft to assure the plungers are fully depressed when the choke is off.
Good Luck!
Good Luck!
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
12 May 2010 04:23 #367390
by riverroad
Replied by riverroad on topic kz1000 ltd carb help
I vote for the vacuum leak as described by Patton. My LTD had the same problem when I first bought it. After jumping through all the same hoops the OP did, I finally yankd my carbs and discovered the previous owner somehow jammed the carbs back on, folding the number 2 carb holder over. It sealed sometimes, and leaked at other times. Talk about banging my head on the driveway! Drove me nuts til I finally found it.
- xxsierraxx
12 May 2010 15:15 #367519
by xxsierraxx
1979 KZ1000
1981 CSR 650
Honda "cough"
So I cleaned, polished and lubed timing advance today, no change. Guess I'll be revisiting vacuum leak. I'll check plugs again as well and see if any are showing signs of running lean.
1979 KZ1000
1981 CSR 650
Honda "cough"
- dpehrson
07 Apr 2013 22:23 #581105
by dpehrson
Replied by dpehrson on topic kz1000 ltd carb help
I am going to resurrect this topic since no resolution was mentioned. I am having the same issue exactly. I have a 2000 KZP...new carb boots clamped well to carbs and bolted to heads ( no leaks). no cable hang-ups. no ignition hang-ups. diaphrams good. slides free and clean. It happened after I pulled it out of storage from winter a few weeks ago...ran flawlessly last fall. Didnt drain carbs before storage.
Help is appreciated greatly
