tubes to airfilter on 75 kz 400 rotted away
  • storysunfolding
  • storysunfolding's Avatar Topic Author
04 Apr 2006 17:56
#36690
Anyone know a good place to find more? The guys at Z1 said no go so I'm stumped.
Maybe I can cannibalize the parts from another bike/year?
  • JR
  • JR's Avatar
Re: tubes to airfilter on 75 kz 400 rotted away
04 Apr 2006 20:01
#36768
I could be wrong here but I seem to remember someone mentioning that they found some sort of flexible rubber tubing type stuff at Home Depot which was the right diameter and fit right in.
Maybe try a search here or in the archives.
Good Luck
Woodstock ON Canada
1980 kz750E1, 4->1, K&N pods
  • hydrolazer
  • hydrolazer's Avatar
04 Apr 2006 20:06
#36771
try kz400.com
\'79 kaw 1000 ltd
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
05 Apr 2006 05:32
#36845
JR wrote:
...I seem to remember someone mentioning that they found some sort of flexible rubber tubing type stuff at Home Depot which was the right diameter and fit right in...
I'm not saying it's great or permanent, but it sure works for testing during my rebuild...
Post edited by: biquetoast, at: 2006/04/05 08:33
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • TonyKZ1
  • TonyKZ1's Avatar
05 Apr 2006 06:10
#36857
The best info I can give on this, if the tubing doesn't work for you, is to get the kaw pn and watch on eBay for these. Mine were pretty nasty and the p.o. had just painted them with some vinyl or rubber type paint. I was able to find a set on eBay. You also might take the part number and check with BikeBandit.com .
Tony
1997 Yamaha Seca II - mostly stock, Oxford Heaterz heated grips, a Scottoiler system. My Mileage Tracker Page
  • georgeha
  • georgeha's Avatar
05 Apr 2006 06:20
#36862
This is one of the reasons I went with pods. The other reason is that the stock air filter is something like $60.
  • Biquetoast
05 Apr 2006 06:40
#36867
Believe it or not, that's the main reason I went with a '76 frame for my rebuild. i wanted the newER style airbox with the cheaper air filters and the rubber hoses from Home Depot. I'm not much of a pod person.
I have I think 5 of those fileters for the '74/75. Some day I'll eBay them...
kz750twins.com
  • peachc
  • peachc's Avatar
05 Apr 2006 08:02
#36890
Biquetoast - do you know/remember what size of tubing you got from HD? That sounds like a good idea!
  • Biquetoast
05 Apr 2006 11:34
#36940
Sure. Here, if you go to this link...
biquetoast.com/bigpics/76-400/rebuild/20...elyCheapAirBoots.jpg
...you can zoom in and see them perfectly. They are 1 1/2".
Also, after thinking about it, I realize that this thread/post is originally about a '75, and this solution really won't work for a '74 or '75 because of the way the hoses on that year airbox are connected... as I mentioned above, that is one of the reasons I chose a '76 frame for the rebuild...
kz750twins.com
  • OKC_Kent
  • OKC_Kent's Avatar
05 Apr 2006 12:01
#36944
Check this thread out, go all the way to the bottom
kzrider.com/component/option,com_joomlab...id,3/id,31253/#31253
Maybe they will work for you
Cashion, OK
78 KZ650 B2 85,000+ miles
