- Thank you received: 10
1976 KZ400, cracked butterfly?
- Kitten Tooth
08 May 2010 20:43 #366642
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400, cracked butterfly? was created by Kitten Tooth
Well, upon dissemblance of the carburetors off of my 1976 KZ400S2, i found that when the butterflies were closed, one was closed and the other was open. I Looked closer and say that one of the butterflies was cracked because whoever tried to clean them before me must have lost the screws to it and used the wrong sized ones and split it. So, what i was wondering if anybody had a set of carbs off a a 1976 KZ400 for parts that they wouldn't mind selling me or just giving me one of the little metal disks that open and close with the throttle. I have money to spend so let me know what you want. I just need the butterfly that opens and closes when you pull on the throttle.
Thanks,
KT
Thanks,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Motor Head
- Thank you received: 391
08 May 2010 20:48 #366645
by Motor Head
Replied by Motor Head on topic 1976 KZ400, cracked butterfly?
Well I don't but this explains some of your Post's with problems. The last owner must have had some problems with loosing screw's or a bad mechanic.
Try EBAY someone would have the Carb's there.
