29s?
- Shaner4KZS
07 May 2010 19:00 #366308
by Shaner4KZS
29s? was created by Shaner4KZS
Hi guys, Put 29s on my 77 and it started smoking really bad! white smoke, has 112 jets, any thoughts??? shaner
- gane
- Thank you received: 1
07 May 2010 21:13 #366354
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic 29s?
Shane, look to your' plugs. It's probable your' running lean enough to burn-off residuals in exhaust. I'm running 117's at 5-7K feet altitude. luck G
- Thank you received: 2098
07 May 2010 21:43 #366361
by Patton
Replied by Patton on topic 29s?
Shaner4KZS wrote:
Would also sniff-test oil and examine its physical condition to determine whether there's any fuel contamination of the oil.
Here's why --- Mikuni smoothbore 29's do not have overflow circuits. If for any reason excess fuel gets past the float valve, bike parked or running, fuel may rise up in the carb and find its way to the crankcase.
Fuel-diluted crankcase oil would then be a suspect for the exhaust smoke.
- Shaner4KZS
10 May 2010 15:56 #367086
by Shaner4KZS
Replied by Shaner4KZS on topic 29s?
Thanx 4 ur help guys an oil change and a set of 117.5 jets did the trick! Shaner
10 May 2010 16:38 - 10 May 2010 16:39 #367097
by Patton
If the old oil smelled like gas, the problem may recur.
Would keep a close eye on the oil level, where an unexplained rise could indicate fuel intrusion.
Different main jets won't resolve whatever issue previously existed.
Last edit: 10 May 2010 16:39 by Patton.
- Shaner4KZS
11 May 2010 16:16 #367302
by Shaner4KZS
It had 34s on it and I am pretty sure they were way too much 4 this bike. Thanx , shaner
