Back to the carbs
- Cigarette38
07 May 2010 13:54 #366237
by Cigarette38
When in doubt upshift
88-95updated GSXR750R
92-06updated GSXR7/12
72' Kawi H2 x2 both blue
79 KZ1000
89 CBR600
02 YZ250
Back to the carbs was created by Cigarette38
To recap I have a 79 kz1000 B3 new to the heard. Got the bike to run but breaks up real bad coming into the needle, only under load. Also found when I turned the bars to the left bike would cut out. Went through the harness and is now ok during movement of the harness but still breaks up coming onto the needle I know I need a sensor diaphragm and a new accelerator pump diaphragm, the acc pump does squirt but not well and the sensor is missing rubber from both sides so I know it is not well.
What I'm wondering is on a test run should I still be able to push past the need for the acc pump and get it on the needle? Can someone explain what the sensor diaphragm does?
Right now the carbs are apart again just to go through and make sure I did not miss a pilot passage or something.
79 KZ1000
89 CBR600
02 YZ250
- otakar
07 May 2010 14:02 #366242
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Back to the carbs
We will not answer any questions until you change your Avatar. :lol: :blink: Shame on you!!! :blush:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
07 May 2010 14:07 - 07 May 2010 14:08 #366243
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
The bike should run fine even without the accelerator pump. Most bikes did not even have them. Breaking up when just coming on the needle might mean that EITHER the needle is too rich or the pilot jet is too big
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 07 May 2010 14:08 by otakar.
- Cigarette38
08 May 2010 07:54 #366415
by Cigarette38
79 KZ1000
89 CBR600
02 YZ250
Replied by Cigarette38 on topic Back to the carbs
Thanks Otakar,
Yes I know that avatar is maybe offensive to some but the old school, oil cooled GSXR's are my first love and with the mutual respect and camaraderie that you guys have on this forum I figured it was OK.
Yeh, after I thought the wiring issues were gone I had to go back to the carbs and thought as you maybe I missed something in the carbs. So they are apart soaking and will go back together later today. Last night I figured out I have an igniter from a 81 kz. Would that make a differance? as well I should point out that right now I dont have a midpipe or muffler just aftermarket header.
79 KZ1000
89 CBR600
02 YZ250
- Cigarette38
10 May 2010 07:11 #366986
by Cigarette38
79 KZ1000
89 CBR600
02 YZ250
Carbs are back on and same problem. I am reasonably sure all is good with the carbs. I think I need to go back to ignition and look closer. As my coils ohmed at 2.8 this seemed high for 79 and thought maybe my spark would be reduced with the 79 igniter. After better research it looks as if I have a later model igniter on the bike so maybe the higher Ohm coils are ok. IDK guess just forge on. Kind of wanted a definitive answer before replacing parts. think maybe it could be just mismatched ignition parts giving less than adequate spark?
79 KZ1000
89 CBR600
02 YZ250
- otakar
10 May 2010 08:19 - 10 May 2010 08:20 #366997
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
If you have a 79 with electronic ignition the coils should be no more than 1.9 Ohms and same with the ballast resistor no more than 1.9 Unless of course you are running 3 Ohm coils without a ballast resistor which is ideal.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 10 May 2010 08:20 by otakar.
