77 KZ 750 B
- bgulsvig
06 May 2010 11:31 - 06 May 2010 12:18 #365931
by bgulsvig
77 KZ 750 B was created by bgulsvig
I have a 1977 kz750 with 6000 miles on it that I have restored. I went through the gas tank, new fuel lines, tore apart and reassembled the carbs numberous times. I have two problems. First when I go to start it I never have to use the choke. In fact it won't start with the choke on. Is this normal? Second it idles fine and runs at low speed but when I get to third gear it starts hesitating and cutting out. Would the carbs being out of sync cause this or do I just need to make some adjustment to the carbs?....thanks...
Last edit: 06 May 2010 12:18 by bgulsvig. Reason: SUBJECT TYPO
- Kawickrice
- Thank you received: 18
06 May 2010 12:13 #365941
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic 77 KX750B
Sounds like its running way rich not having to use the choke to start it, and getting to much fuel in the higher rpm's causing a hesitation.
From the heading I thought you had a 750 dirtbike project going
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- bgulsvig
06 May 2010 12:26 #365944
by bgulsvig
Replied by bgulsvig on topic 77 KZ 750 B
I removed the in-line fuel filters that were on it. Would that make it run rich. I haven't made any adjustments to the carbs. What do I need to adjust to lean it out? It has duel carberators....
