High Idle Question???
- Fozzie
05 May 2010 19:22 #365829
by Fozzie
1982 KZ1000J
High Idle Question??? was created by Fozzie
Arite fellas,the ol KZ is running pretty good now. No more leaks from the pods and shes firing right up at the push of a button.But after cruising around for a few minutes, when I get to a stop light or something and pull the clutch its idling high or turning like 3K rpms. It will smooth out after a few minutes but if I release the clutch to take off or shift to a lower gear its ok,just when I pull the clutch. Any ideas on where I should start( I already checked the throttle cable to see if its getting kinked or hung).
1982 KZ1000J
- TeK9iNe
- What did you do!?!
- Thank you received: 28
05 May 2010 19:56 #365833
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic High Idle Question???
This is a classic symptom of being too lean.
Could be an air leak, or your mixture screws are too lean.
Have you set the mixture screws properly?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
05 May 2010 20:38 #365837
by Patton
Replied by Patton on topic High Idle Question???
If not already done, with engine running at normal operating temperature, could try reducing idle speed by turning the thumb screw idle adjuster.
- Fozzie
06 May 2010 13:22 #365960
by Fozzie
1982 KZ1000J
Replied by Fozzie on topic High Idle Question???
So I have adjusted the idle to around 5 hundred rps. Runs fine still idling high at stop lights whenever I pull the clutch to stop. When you say airleak, where? And this is a common syptom of an air leak?
1982 KZ1000J
