Thought I had it working
- BIGD
05 May 2010 17:25 #365815
by BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
Thought I had it working was created by BIGD
Just rebuilt my carbs. Placed them back in my bike. The bike started after a few turns, but was idling a little rough, and KZ Riders suggested a carb sync for the final finish to the job. Went back to my parents to pick up the bike and it will not start. After much looking around, I think gas is filling in the float bowls but is not entering the intake. Any ideas would help, but I think I will take them a part clean and dry again, and put back together. Thanks Don
- Kawickrice
- Thank you received: 18
05 May 2010 19:11 #365828
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Thought I had it working
Did you check the float height? Dont feel bad it takes a couple of times sometimes to get it worked out
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- TeK9iNe
- What did you do!?!
- Thank you received: 28
05 May 2010 20:07 - 05 May 2010 20:09 #365834
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Thought I had it working
Carbs can be a real PITA.
There really is only one way to be sure the carbs are going to flow properly.
You must completely dissasemble all of the entire carbs.
Take every little bit of rubber out of those things and get a can of spray carb cleaner.
Spray the carb cleaner thru every passage way, looking for where the cleaner is exiting. Spray through the pilot jet hole and make sure its coming out all the little pilot holes in the carb bore, and the same for all the carbs.
If a pilot passage is clogged, you can use a single strand from a stainless steel brush to poke thru the debris, then keep spraying. Empty that can of cleaner on those carbs!
Then setup a jig of some kind, in order to set the fuel height while off the bike.
Its so much easier.
Once your done, those carbs will not be the issue unless you have redically changed the intake or exhuast systems (pods, velocity stacks, 4-1 exhuast, etc.)
GL!
Its so much easier.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 05 May 2010 20:09 by TeK9iNe.
