Inital starting problem
- Nats82
01 May 2010 06:50 #364671
by Nats82
Inital starting problem was created by Nats82
Hi Forum,
I have a 82 550ltd. At starting, the choke must be on. Once the bike is started it idles rough I have to keep playing with the choke. After about three minutes or so, I can close the choke, but can't throttle up or it wants to die.
After a whopping five minutes or so, the idle smoothes out a bit, and after all this the bike runs great. It does seem to be running just alittle lean, so I'm not sure this is some of the problem on inital start up or not. It seems to me it shouldnt take quite that long to warm up, and get the idle and responsive throttle. Any input from the forum would be greatly appreciated.
- ditchdriver
01 May 2010 08:47 - 01 May 2010 09:08 #364693
by ditchdriver
1982 kz 550 ltd
Grand Forks, ND
Replied by ditchdriver on topic Inital starting problem
how does ur choke flaps look if its running lean one or more of ur flaps could still be open.
there are several post in here about it im not very knowlege able about them yet as i just took mine off the other day and havent got to crack them open yet but there are some very intelligent people in here that can help.
might try lookin at these maybe they can give u some insight. if this is ur problem but remeber "if it aint broke dont fix it".
kzrider.com/index.php?option=com_kunena&...76443&catid=3#276443
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=313180
1982 kz 550 ltd
Grand Forks, ND
Last edit: 01 May 2010 09:08 by ditchdriver.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
01 May 2010 15:26 - 01 May 2010 15:27 #364767
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Inital starting problem
Once you have been riding around on the bike for a while (30+ min.), adjust your mixture screws.
Turn them 1/4 per a couple seconds, at a time and listen to the idle.
When the idle drops, stop. Then turn it the other way, counting the # of turns till the idle drops again.
Put the screw back half the number of turns. Directly between the idle drops.
If you start turning the screw and the idle jsut keeps going up and up and doesnt drop till the screw is either seated or all the way out. Then you may have an air leak, or a bleeding enrichener circuit.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 01 May 2010 15:27 by TeK9iNe.
- Nats82
01 May 2010 18:53 #364824
by Nats82
Replied by Nats82 on topic Inital starting problem
Thank you Ditch and TeK9ine There's not doudt that the manual is a must!! it's done me well in the past, sometimes there's nothing like the forum!! Thanks again!
